Dyno run test - 930-78 ??
Hi, I will next week have my 930 -78 on a dyno run test, and will hear if there is anything special I should be aware of or take into account, before and during the test?
Regards John |
I also did it a few month ago, probably like you to know if my stock engine is in good shape after nearly 160 000 kms, I just changed the air filter for a K&N and drive it one hour before the test to warm it. I got 294hp and 41,2mkg of torque for a 1987 model, quite Happy of the result!
Next try will occur with a K27 turbo charger and a 0,9 bar boost spring to check the difference. good luck! |
Nothing critical about it, strap it down good and hold on... a big fan by the engine bay will help the heat sink issue + another one on front the oil cooler.
As always, pictures are due right after. Let us know how it turns out. |
| All times are GMT -8. The time now is 08:48 PM. |
