cellison great idea. Looking at your engine I notice an MSD coil yet you have the bosch CDI? Thought they were not compatible. JMHO
Yes, the cdi and coil should match.
very timely thread (below) on the MSD coil / Bosh CDI compatibility question. thanks for bringing this to my attention.
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/697025-msd-8202-coil-cdi.html |
well i took the timing light and hooked it up to the coil to dist wire plug and did not get any light when the car was started. it appears my next step is to pull the new/old coil and CDI back out to verify those are are good (or hopefully confirm one is bad). More questions:
1.) is there another bench test i can perform on the coil other than checking resistance to see its it is ok? 2.) when i plug my ECU box in another car to check out, do i need to physically ground the box to the other car? it being cast iron or something and attached to an aluminum plate i would not think so.....Last time, i plugged mine in the other 930 and set it next to hos ECU (still mounted) and it would not start, and ECU Drs said mine was shot hence the rebuild. thanks for everyone's continued help. maybe this thread will die soon. |
That's interesting info regarding the use of MSD 8202 coil with Bosch CDI.
The MSD coil on my car was recommended by others when I was trying to track down an ignition problem a few months ago, so I bought one to try. It works fine, but as it happens, so does the original coil because the problem was elsewhere in the wiring. I think I'll swap them again just to be sure. Definitely don't want to cook my CDI. Thanks for the tip. |
Have you checked the "green" wire coming from the distributor? My guess is that you are not getting a trigger signal at the CDI due to a bad wire. There are many threads on this.
If you have an osilloscope you can check the signal to the CDI. You might be able to pick it up with a Digital MM set to AC if the range goes low enough. |
Sounds like a similar issue I had a year ago. no start, no spark. after replacing ignition box, coil, rotor, wires, plugs, still no start.
Check the big harness plug in connector in the engine compartment left side near the ignition box. I had bad corrosion on the connector and had to do a hardwire jumper. Make sure you have 12 volts coming into the ignition box, make sure you have good grounds as well. I agree an o-scope on the dizzy wire would be a good check as well. good luck, cars are getting old and electrics do act up with age... |
Quick update. i have had several on the board reach out to me to provide valuable "on the phone tech support", and the best part is i did not have to call India :) (poke at where my companies IT support is located). Without this board i may not be in this hobby how deep i am. One board member is providing me a good working Bosh CDI, good bosh black coil, non rev limiter rotor, ignition delay relay, and new green wire to help with my diagnosis. i am taking some vacation next week, so i will resolve this one way or the other.
Well to close this thread out, i didn't have the coil wired corectly. I rewired it and barly hit the started and it fired right up. Best sound in the world at that this moment. The lesson learned for me is to label stuff properly.
Great news. Congrats!
Good news and congratulations. In addition to (or instead of) labelling, I find that snapping a load of digital photos is very helpful to refer back to when trying to put things back together. A recent example was when I pulled my front bumper. Rather than label the front running/turn signal wiring, I just snapped a close up shot with my cell-phone cam. When it was time to put it all back, I just looked at the photo to make sure I got the wires back correctly. |
| All times are GMT -8. The time now is 07:11 PM. |
