-   -   O2 Sensors at Autozone (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/708243-o2-sensors-autozone.html)
sundevil64 09-25-2012 03:14 PM
Throwing this out there. I found a Bosch O2 Sensor at Autozone to be cheaper than anywhere else. $51. I bought one for my Innovate Lc-1. Between the occassional oil special an these sensors I was quite pleased with Autozone values. As far as service and value, ehhh keep your expectations low.
SmileWavy
Miguel Antonett 09-26-2012 06:19 AM
So, how does it really work with the Innovate, or doesn't?
9dreizig 09-26-2012 06:26 AM
I"ve done the same, they are the exact unit.. I believe for the LM2 it's originally a VW p/n
sundevil64 09-26-2012 06:56 AM
They work fine. I pulled the number from DIY Auto tune and called Auto Zone.
sjf911 09-26-2012 08:19 AM
I just replaced mine with the same sensor courtesy of Autozone, works great.
jsveb 09-26-2012 01:52 PM
What is the autozone part number?
sjf911 09-26-2012 01:59 PM
IIRC it is a Bosch 17014.
jsveb 09-26-2012 02:44 PM
turbo nut 09-26-2012 02:48 PM
They are used on 2001 VW Jetta 1.8 turbo and many other vw vehicles.
mooney265 09-26-2012 03:08 PM
are these wide-band? thanks...
JFairman 09-26-2012 04:04 PM
Yes, it's the exact same mass produced bosch wide band sensor innovate uses.
Innovate used the vw wide band sensor because the pigtail is a convenient length and the water proof plug on the end is the one they use on their stuff.
Other chain stores like Advance auto parts has them too and you can order one online from amazon for about the same price.
Getting it local is better since you can return it if it doesn't work.
sjf911 09-26-2012 05:15 PM
Yep, 17014, here's my spare:
http://forums.pelicanparts.com/uploa...1348704880.jpg
sundevil64 09-26-2012 06:49 PM
Some of the stores allow jobber pricing to some corporations particularly those with fleets. I'll have to see what ours is at Advance. I had forgotten all about that.
