Alan L's Avatar
recirc valve seals
Any one know what they are made of. may try making a couple.
I could order from Pelican (and may do). But timewise it would be helpful if I could make a couple now. Just ordered some stuff from pelican this morning. Bugger. Maybe they would have consolidated shipping. $40 shipping on a $10 part. Aagh.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 01-04-2023, 05:20 PM
proffighter's Avatar
Hi Alan
You mean the two 93011014900 right?
I know that in the 80's it was different that nowadays as I replaced mine in 2000. The new part was (and still is looking at pictures now) some kind of soft Nylon. But I guess it does not matter that much as long it is resistant to fuel/oil and withstands the hits of the piston (for this reason I guess Nylon).
Roland
930 Turbo '81 Too many modifications to list
Old 01-05-2023, 03:24 AM
Did you try a P car dealer? For small stuff I start there and sometimes get lucky. Having an enthusiast at the Parts counter helps.
Old 01-05-2023, 04:14 AM
Alan L's Avatar
Thx Roland. I think also it needs to seal reasonably well also.
DC66 - chances of finding any in this country are near nil. You could count the number of 930s on your fingers. But I will give it a shot anyway.
Thanks guys
Alan
Old 01-05-2023, 09:53 AM
mark houghton's Avatar
I would try high temp silicone
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 01-08-2023, 08:32 AM
Alan L's Avatar
Hi Mark. Believe it or not - I found some - in my shed.
My memory ain't what it used to be, but it is a while since I used the stock IC. Changed to a 965 one ages ago, and ditched the recirc valve. Been fitting the stock system back in (:-( ) for some racing coming up shortly.
Regards
Alan
Old 01-08-2023, 09:41 AM
