-   -   BOV/DV question on Ruf intercooler (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/712226-bov-dv-question-ruf-intercooler.html)
speednme1 10-19-2012 10:51 AM
Hey folks,
I was fiddling with my car the other day and noticed that the factory bov/dv has been removed(probably by previous owner).
My question is can I just add the 964 turbo elbow with a bov(Synchronic DV001x) and connect the output of the bov to this location on the Ruf intercooler(connects to the throttle body)
http://forums.pelicanparts.com/uploa...1350668953.jpg
http://forums.pelicanparts.com/uploa...1350669006.jpg
thanks
speednme1 10-19-2012 12:58 PM
by the way on that old school fuel injector, it's only purpose at the moment is as a plug.
oilonly 10-19-2012 06:51 PM
I would think you could do it there, someone else better confirm though.
aerodyn930 10-19-2012 07:21 PM
Hello, yes the 965 elbow will work but the source for the recirculating valve needs to connected before the throttle plate, I believe the Ruf I/C did not have a provision for this, Post more photos of your intercooler and the connection to the throttle body and we can suggest a solution , BTW it is not clear in your photos if that additional injector is mounted in a location that would satisfy the previously mentioned criteria,
Regards, lou
speednme1 10-19-2012 07:56 PM
^^^^I will have to remove it from the car or find a similiar photo.
speednme1 10-19-2012 08:05 PM
Regards, lou
Ok here is a photo I found. My location is similiar to the location of the red cap on this pic( I apologize for using someone elses pic)
http://forums.pelicanparts.com/uploa...1350702298.jpg
aerodyn930 10-19-2012 08:26 PM
Yes that would be a correct location , Finding a thread on nipple of the ideal size may be difficult, Maybe welding a nipple to the I/C can provide a solution, Possibly a elbow so that the hose coming from the recirc. valve does not have to make a very tight bend,
Hope this helps ,, lou
speednme1 10-20-2012 01:17 AM
Yes it does..thank you very much.
