kodioneill's Avatar
Tune up on 77 turbo question with photos.
Working on a customer car I found two things and need to know why the PO did them.
I think the oil pressure "looking" switch is the over boost switch. The po disconnected and grounded it I don't know why.
Also the vacuum line is plugged " the one with my hand in photo" coming from the BOV unit. Where doe's it go and why would it be disconnected?
Thanks for any help.
Mike
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 10-22-2012, 07:46 AM
908/930's Avatar
Hi Kodioneill,
The overboost switch was probably getting old and switching off so they bypassed it, should install new one. Not sure about the vac line.
Rod
87 930 GPW, Monty muffler.
Old 10-22-2012, 08:26 AM
tomdeg's Avatar
Vacuum line should do to diverter valve. Is the air pump missing or disconnected?
Old 10-22-2012, 08:37 AM
kodioneill's Avatar
The air pump is gone. Thanks guy's for your help.
1982 chiffon 911sc
Old 10-22-2012, 12:43 PM
Dan Jessup
I was thinking is was some sort if air sensor that was grounded... So what did you find was the reason they grounded the overboost?!?
Here is a pic of my situation --- the PO said he had a stalling issue years ago?!?
Old 05-06-2013, 08:36 PM
I over-boost switch is part of the fuel pump circuit. When the pumps start to get old they draw more amperage which cause that boost switch wire to get hot. The center of the boost switch is a plastic diaphragm which ultimately melts causing start and running issues.
I had 2 fail in short order and not wanting to invest in a new pumps I elected to solder my switch closed and continue to use it.
I need to budget for the pumps.
Tinker
Old 05-07-2013, 09:05 PM
