disscetion EZ-69
the ez-69 is glued together ..top goes on in 2 pieces .the 1st piece has fine pins that make contact with the PCB .
there is no way to get this apart gracefully
can it be fixed ...maybe
will it ever look the same ....no
the two PCBs are covered with a clear jelly like substance
if you look at the top right you can see a smoked component it is not mounted to the main PCB
and has small wires connecting it to the PCB they are brown and black ....the component is connected to pin 16
i take apart competitors equipment (not to reverse engineer but to see what they are doing)
and this is a bear to take apart and you run the risk of further damage doing so
I would not try to repair this item and I defiantly would never do it for a customer
stefan
Old 11-29-2012, 04:13 PM
sudo apt-get purge 930
equality72521's Avatar
random....
--clutch-monkey
Old 11-29-2012, 05:57 PM
mark houghton's Avatar
Sure wish I had one of those high-tech units in my 930....NOT. Looks like a nightmare. Thank God for CIS and it's simplicity.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 11-29-2012, 06:33 PM
Actually that part is on 964 Turbos (w/ CIS)....
Brandon
'91 911 Turbo
'00 Audi S4 highly mod'd DD
Denver, CO
Old 11-29-2012, 08:03 PM
spence88mph's Avatar
It logs how sh#t the fuel delivery is.
'89 911 M491+Turbo
'89 944 Turbo
'88 928S4
'18 C63S Coupe
Old 11-29-2012, 08:08 PM
ignition control.....
Brandon
'91 911 Turbo
Denver, CO
Old 11-29-2012, 08:09 PM
I've gone native
Tt surgeon's Avatar
Exactly
Old 11-30-2012, 03:35 AM
Wide body, molester.
H20 LOL's Avatar
Lol
91- 964T, It's upkeep treats me like a skinny white kid in prison, but it does give me a reach around every now and then by letting me drive it. That's not so bad.
Old 11-30-2012, 06:52 AM
Crotchety Old Bastard
RarlyL8's Avatar
The EZ69 unit is electronic ignition control which is used much more often with EFI than CIS. Failure mode is consistent with all things electronic.
Old 11-30-2012, 07:06 AM
TurboKraft's Avatar
Cool, Stefan! Thanks for sharing.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 10-20-2014, 11:02 AM
Chain fence eating turbo
Clear jelly is called conformal coating. Basically waterproofing for the components.
Old 10-20-2014, 11:57 AM
Kartoffelkopf
Spenny_b's Avatar
[shamelessplug]
I'm rather glad that I have an A1 condition, working example, stashed away somewhere very safe. Hens teeth...rocking horse s**t, etc...Never to be used again on my car, but stored with all the other Euro CIS kit that I no longer need
[/shamelessplug]
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html
On Instagram (along with other stuff) as @spenny_.b #spennybengineproject
Old 10-23-2014, 12:37 AM
Bad LT
Uncle's Avatar
lol.
Old 10-23-2014, 01:54 AM
Metal Guru
911nut's Avatar
The EZ-69 failure potential is the only negative to owning a 964 Turbo. Porsche wants $5000 for a new one (so I hear) and used replacement units, while they can be had for $500-600, are hard to come by. Other than that, the 964 Turbo uses the same 3.3 engine that the 930 uses, including CIS with it's non-linear fuel delivery.
Paul B.
'91 964 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, - 210 lb
Old 10-23-2014, 05:22 AM
At that cost, EFI sounds like a bargain.
Old 10-23-2014, 05:37 AM
Kartoffelkopf
Spenny_b's Avatar
Think you'll be doing (very) well to get one for $500-600....I turned down more than that in GBP a short while ago. At the time I was undecided whether to keep all the stuff I removed, CIS, ignition, etc, all together (either stashed for a rainy day or to go as a job-lot), or sell off items as/when..... In fact, still undecided; I guess I'd prefer to let it all go in one shipment TBH, clears me more space and would get me that Speedmaster Pro 45th Edition I've got my eye on!
Old 10-23-2014, 06:05 PM
