-   -   Reverse Light Switch (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/721562-reverse-light-switch.html)
MikeD930 12-02-2012 05:44 PM
My reverse light switch started leaking on my '87 930 (I believe from within where the electrical connectors plug into). Does anyone know that part number for the switch the fits '77 through '88 930? I did not see it listed here on pelicanparts.
Also, it looks like the transmission needs to be dropped to RR the switch. Is this the case? Or can it be access after lowering the transmission (not sure how far it can be lowered with shift rod through the tunnel)? Or how about holding the transmission with a jack and remove the transmission support?
Any suggestions are appreciated. Thanks.
Tt surgeon 12-02-2012 08:50 PM
It's in the pelican parts section, I just did this recently, an east diy from the bottom with a simple floor jack. 30min max.
Look under backup light switch 39$
fredmeister 12-03-2012 10:25 AM
A floor jack to support and remove the tranny cross member to get at it.
Do you need to drain the tranny fluid or not to do this?
Tt surgeon 12-03-2012 10:43 AM
I actually just jacked the car up and crawled underneath. I used a box wrench, 123 done. The biggest pia I had was one of the wires had been jury rigged by the PO, I had to solder the end.
MikeD930 12-03-2012 03:13 PM
Thanks for the comments but I can only find one switch (p/n 914-613-541-02-M253) which is listed for 1965-1969 911/912. Is this the one you ordered?
Tt surgeon 12-03-2012 03:20 PM
Yep
MikeD930 12-03-2012 03:22 PM
Ahh...thanks! Pelicanparts need to update their parts info (expand on years) for this switch.
Tt surgeon 12-03-2012 04:45 PM
If u look under 87 911 the same part pops
JFairman 12-03-2012 05:17 PM
They used to be around $90 when they were made in europe and I see that one is a URO. Pelican Parts - Product Information: 914-613-541-02-M253
I think they're made in china.
It might work a long time who knows. I wonder what the dealers are selling now.
