Rejuvinating my '91 964 Turbo
Bought the car back in '02 from TN and as usual, the Porsche dealer that did the PPI, missed the slight oil leak the car had :to_order:
Local Porsche dealer didn't want me to go after the PPI'ing dealer () which I didn't but should have, any way leason learnt.
Well since I don't drive the car much, it didn't cause much problem but the oil leak always bothered me.
I spent countless number of hours/$$$$ with pretty much every Indy Porsche Mechanic here in KY while chasing those oil leaks and trying to set up the car the way it should handle, but I always came back regretting.
Talked to Dan Jacobs about 2 years ago and finally decided, it's time some one who loves and apprciates these cars, to work his magic on the car.
Here it is, on it's way to Hairy Dog Garage, CT
Old 03-03-2013, 11:27 AM
Plan was to drop the motor and do what ever is needed to not only stop those annoying leaks but to also rejuvuinate what ever needs rejuvinating
Clutch:
964-423-477-00 Clutch Hose 1
950-116-237-50 Clutch Slave Cylinder
SUPER GOLD Super200 Gold BrakeFlu
Major Service: Perform major service. Read out system faults. Change oil and filter. Perform valve adjustment. Change spark
plugs. Change fuel filter. Change transmission fluid. Clean and recharge air filter. Lubricate door hinges and seals. Perform leakdown and compression test. Replace power steering, A/C, and alternator belts. Remove and
replace alternator belt sender. Remove air pump belt.
Check belts, hoses, brake pads & rotors, steering gear and fluid, ball joints, drive shafts, exhaust system, tires, horn, lights, windshield/headlight washers, battery fluid level, warning light function, function of oxygen sensor.
Road test for brake pedal, clutch and transmission and drive train functions.
99-0624 Air Filter Cleaner
Old 03-03-2013, 11:42 AM
So those were the main things that needed done.
Baron (Dan's son) is also helping me customize some other stuff that I couldn't get it done here in KY.
I will post some more pictures later
I am pretty sure you all are familiar with Dan Jacob and his crew but for me it was a big step sending the car to him 1100 miles away.
I am very pleased and content with my decission.
Old 03-03-2013, 11:58 AM
