I've gone native
Tt surgeon's Avatar
I guess I meant always in going from OEM to permatune, if one replaces the OEM cdi w a permatune cdi, one should also replace the coil with a permatune coil.
Old 01-19-2013, 06:11 PM
Turbofrog
smurfbus's Avatar
Good to hear all is good again : )
79 930: HX40S#16, MS3pro+ID1000+044+E85, Ignition: 123/TUNE/MSD6A, True split BB, 2*turbosmart38
Old 01-20-2013, 07:53 AM
Tinkering Pays!!
mooney265's Avatar
So, those guys were good to deal with? Could you post a picture of your new unit, just curious if they are all they say they are... Thanks!
Originally Posted by 1986911 View Post
Update, new cdi box and problem is gone. The 31/1 wire goes to ground on one of the two studs that coil attaches to. I mistakenly said it went to the negative post on the coil. I checked all my ground resistance and all was good. According to the ECU Dr's that melting of the 31/1 link is pretty common, I was concerned a poor ground caused the link to melt.
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR.
Old 01-20-2013, 08:22 AM
1986911's Avatar
Too late, already in car but it looks brand new. Not sure of the clear coat on it but definitely bead blasted and new decals. I will try to get some shots of it but it looks awesome. I can't open it because they put a tamper seal on it but you can't beat a 5 yr warranty.
My old epoxy coil checked out fine so I cleaned it up and put it back in. I did also manage to get an almost new epoxy one (Thanks Todd). Once the semi new one arrives I will swap them out and keep my original one as a spare.
Still on the hunt for a NOS coil though!
MG---1986 911 TARGA, SSI'S, STEVE WONG CHIP, M&K EXHAUST, ELEPHANT RACING GOODIES + TRU DESIGN CUSTOM FUCHS
1989 930 FACTORY SLANT NOSE -- RARLYL8 EXHAUST, K27 7200, TIAL 46MM, 0.9 BAR SPRING, GARRETSON INTERCOOLER , LEASK WUR, WEGO IV AFM AND NHS BOOST GAUGE.
2012 DODGE RAM 3500 LONGHORN 4X4 "EVERYTHING BUT THE KITCHEN SINK"
Old 01-20-2013, 10:26 AM
T77911S's Avatar
my 31/1 goes directly to the coil on my car. but, at the CD onnector, there is also a larger brown wire tied in with the br/w wire from the coil. that wire is attached to the stud next to the coil.
hi current makes something like that blow. a short in the coil windings perhaps. maybe even the + to the coil shorting to the - from the coil.
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 04-24-2013, 06:47 AM
