-   -   stock boost question (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/731321-stock-boost-question.html)
red 930 01-29-2013 05:22 AM
I have a stock 76 930. What should be the stock boost (in mb)?
I'm running at .75 now.
Les Paul 01-29-2013 08:54 AM
1 bar is 14 and change if I recall. I would think .75 would be 11-12? I'm sure someone here can pinpoint it. Are you going off the original stock gauge?
02fly 01-29-2013 08:59 AM
No gauge in a 76.
RarlyL8 01-29-2013 09:21 AM
Stock boost level on the intercooled 930 is 700-800mb. I believe the non-intercooled boost levels are similar as the C/R was lower on those 3.0L engines. I can pull out the manual if you need a spec range.
911nut 01-29-2013 07:00 PM
1 bar = 14.7 PSI
.75 bar = 11 PSI
