Kozmo930's Avatar
so if I keep around 400hp 1.5 primary should be fine ? I am only planning on your header set up , zork tube with bigger intercooler. EBS is hooking me up with some cams, so I am not getting to wild. I do have question about the dual waste gate option, everyone talks about boost creep does that mean that if you are doing PDX with your car ... under load all the time boost is a real problem to control with a good header setup ?
Old 06-18-2013, 05:10 PM
Crotchety Old Bastard
RarlyL8's Avatar
Kind of beyond the scope of this thread but I would recommend 1.63" primaries for 400WHP. We offer both sizes. Boost creep is an issue with "elephant nose" design headers. We addressed that issue by taking a smooth bend off of each bank to a Y joint terminating in a common tube to the waste gate. Dual waste gate option is optimal for true twin scroll turbo use. Precise control of boost using 38mm WG for each bank.
Old 06-18-2013, 05:31 PM
