-   -   Advice on MDS ignition components needed (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/739811-advice-mds-ignition-components-needed.html)
flat_6 03-19-2013 06:12 AM
Guys, I want to go to MSD ignition on my 930. Looking at the 6AL, what other components do I need?
What coil?
Do I need a Tach/RPM adapter?
Recommendations/advice would be appreciated.
Thanks,
Mark Henry 03-19-2013 06:47 AM
Depends what you're doing, (what are you using now, is it twin plug, etc.?) base is a 6al and use a MSD blaster coil.
I have a tach adapter that I won't be using. You need one if using a stock VDO, I'm using a Autometer and you don't need the adapter with those.
turbobrat930 03-19-2013 07:27 AM
Also, take a look at using M&W ingnitions instead of MSD....
mooney265 03-19-2013 07:56 AM
A good read: http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/610488-msd-success.html
flat_6 03-19-2013 08:10 AM
Thanks guys. Keep the advice coming.
Also, I have single plug not twin plug.
Oheggem 03-19-2013 08:45 AM
I have a 6425 unit with coil and all hardware and wiring. Never installed as i`m going with distributorless Xdi unit instead.
I can give you a good deal on this if your insterested :) Let me know.
turbo nut 03-19-2013 02:28 PM
My 82 had a 6AL for years with no problems as long as you use the correct rotor witout a resistor. The tach worked fine plugged right into the sideof the MSD no tach adapter needed in my case. If you do a search on the suject of the rotor with MSD there is plenty of info.
mark houghton 03-19-2013 02:29 PM
Ditto for me....
flashgordon64 03-19-2013 03:35 PM
If you're looking for a locked dizzy I have this leftover from my MSD sale.
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/696699-fs-rebuilt-930-distributor.html?highlight=msd
flat_6 03-21-2013 04:26 AM
You guys are a great help. Thank you!
