-   -   GHL headers cracking (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/739944-ghl-headers-cracking.html)
sundevil64 03-19-2013 07:01 PM
Well it looks like the heat cycles have finally had their way with my headers. I believe these are GHL's. Can these be repaired on the vehicle or do they need to come off? I think I know the answer, but...
http://i475.photobucket.com/albums/r...ps6da5ae6c.jpg
http://i475.photobucket.com/albums/r...psa707570c.jpg
http://i475.photobucket.com/albums/r...ps0a5a1637.jpg
timc 03-20-2013 12:38 PM
If it were me, to be safe, I'd remove. The last thing you need are loose welding "particles" flowing thru the turbo. This way you can run a chain of some sort thru the pipes to knock of potentially loose metal from the welding process....
Tt surgeon 03-20-2013 01:05 PM
Agree, time for a new set.
kupcar 03-20-2013 01:14 PM
That happened to mine also. I took them off, cleaned them, and then repaired the cracks. It's a good idea to make sure there is no slag sitting in the headers after repair. That being said, it's best to take them off to repair.
sundevil64 03-20-2013 08:57 PM
exhaust
These are SS correct? Did you do the work or did you have someone do the work? I was wondering how you cleaned the carbon out of them on the inside?
Thanks,
John
kupcar 03-20-2013 10:28 PM
John, Yes they are stainless. Cleaning was more prepping the cracks on the exterior by grinding. We did run them through the parts washer which did a decent job. My brother did the welding. After we ran a chain and cable through the headers to check for any debris. We also used an inspection scope to take a look around. This was a couple of years ago. They are working great. No more cracks.
sundevil64 03-21-2013 04:57 AM
Thanks kupcar.
