beancounter
jwasbury's Avatar
If I ever decide to sell my car, I'm flying you up to NJ to take the photos
In the years I've been hanging around this place, I don't believe I have ever seen pictures of your 930. Very, very nicely done. Is that a Kokeln I/C that you've polished and "debadged"?
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 03-28-2013, 06:14 AM
rsrfan's Avatar
I love the shot over the worn drivers seat bolster. As immaculate as the car is, it is obvious that it gets driven as it should. Very very nice Jim...
JP
86 930/4 tribute beasty
81 sc beach beater
55 Belair
40 Ford pickup
Old 03-28-2013, 08:25 AM
Brando
quattrorunner's Avatar
Wow! makes me want to polish my intercooler too.
Turbo powa!
1977 911s. it's cool
Old 03-28-2013, 09:09 AM
[QUO1 TE=jwasbury;7355341]If I ever decide to sell my car, I'm flying you up to NJ to take the photos
In the years I've been hanging around this place, I don't believe I have ever seen pictures of your 930. Very, very nicely done. Is that a Kokeln I/C that you've polished and "debadged"?[/QUOTE]
Thanks, and I'm sure that would be fun!
Yeah, it's Kokeln I bought from someone here a couple years ago. I ground off the name Kokeln Racing and progressively sanded the rough sand cast end tanks down with finer and finer grades of sand paper on an 8" DA sander until they were smooth and then polished them with a 4" buffing wheel using rubbing compound and then polishing compoud on a die grinder.
It took a while.
It could use some hand rubbing with "never dull" to shine it up more. I havn't done that in a while.
Old 03-28-2013, 10:27 AM
Well done Jim! Are the cams from my car in there? Absolutely beautiful.
Lincoln Phillip
87 930 Motec EFI M600 G50/50 TurboKrafted Hell Hound.
Jeep, Chrysler, Dodge, Ram, SRT & AEV Dealer pm me for your Mopar needs.
"the 930 is THE CAR that started my PORSCHE love affair..." Magnus Walker
Old 03-28-2013, 12:25 PM
Hi Lincoln, thank you!
When I took out my worn cams and rockers back in 2006 shortly after buying the car to rebuild the valve train I found they were stamped Webcam grind #40 on the end. So I called them and found out thats their 964 grind.
It was a back and forth decision for me what to do then. Have the 964 cams repaired and keep the high rev power band they give or go with your SC 330 cams I already got from you that are said to give more midrange performance somewhere in between SC and 964 cams.
I decided to send the 964 cams back to Webcam and have them repaired and then around a year later I sold your cams for what I paid for them to Mark Houghton. I don't know if he's installed them or not.
I hope you get your car back soon and hope it's powerful and reliable for a long time. Take care and good luck!
Old 03-28-2013, 02:11 PM
Thanks Jim, I will take all the luck I can get.
Lincoln Phillip
Old 03-28-2013, 02:15 PM
Looks great!!!
What is your wheel offsets?
Old 04-03-2013, 06:22 AM
I would have to jack up the car and remove them to see what offset number is stamped on the back of the centers and I'm sorry I just don't feel like doing all that right now.
All I can say is they are RH P-3.6 wheels made for a mid eightees 930 while retaining the origonal rear wheel spacers. The rear wheels were origonally 10" wide and I took off the origonal outer barrels that were bent when I bought the wheels used and installed new 1" wider outer barrels I got from Jim Dorociak to make them into 11" wide wheels. Then I installed the wheels without the origonal 28mm rear spacers. These wheels clear the rear calipers without the rear spacers installed and not all aftermarket wheels will do that.
That keeps the same backspacing but adds another inch to the overall width of the wheel.
After I did that I think he's done the same thing for other people so maybe he knows what the offsets are or what the backspacing is. I don't know if backspacing measurment is the same as offset measurment.
Here's the place that sells these wheels in the USA. Maybe you can figure out the origonal offset of the wheels from there. Maybe calling GMP and asking what offsets fit a stock 930 with the origonal rear spacers installed will help.
RH Wheels Porsche P-3.6 (P2)
Sorry I can't be of more help. I changed the outer barrels or wheel halfs to 1" wider ones. All I know is they fit perfect, look great, and never rub anywhere.
Old 04-03-2013, 07:53 AM
MikeD930's Avatar
JFairman,
I had no idea your 930 is so nice! Love that color. Good job presenting (photos, car and all) albiet 7yrs late!!! Not sure if you already showed your 930 before though.
MikeD
'87 930
Old 04-03-2013, 08:46 AM
Old 04-03-2013, 11:05 AM
redturbo911's Avatar
Wow that car is amazing and the wheels look perfect. More pics of the wheels and depth when you get time. Thanks.
Tony
91 964 c2 black/ Work in progress/Finally back on the road
85 EURO 930 Black slightly moded slowly reviving her
77 911tt EFI wide body red/ Slightly modified SOLD
Old 04-03-2013, 12:00 PM
