twin plugged targa's Avatar
Fan shroud help please!
My 87 930 fan shroud (cooling fan surround) has cracks on the supports
I would rather find a replacement than try to repair the magnesium.
I have found a shroud (on Ebay) for a 76-79 turbo - Part number 901 106 1015R.
Mine is part number 930.106.102.4R
Is there a huge difference?
Will the older shroud fit mine?
I believe the older 76-79 has a smaller alternator and so maybe mine will not fit.
I just installed a new alternator in mine, so buying a new alternator to fit the smaller shroud is not ideal.
Anyone know of any other shrouds from other 911's which should fit??
I know when I had my 86 911 Carrera (which also had a cracked shroud) an SC shroud fitted!
Any advice appreciated
Ben
AKA "86ragtop" 1986 911 Carrera SOLD 11/2001
1971 911T Targa - twin plugged 2.7 230HP SOLD! 2/2008
1970 911T - ivory white -SOLD 2/2012
1987 930 - sold 2018
Currently in-between 911's
Old 04-09-2013, 08:35 AM
This may help:
88' 930
03 Tacoma, 04 Duramax, 06 R350 Benz
If you are traveling at the speed of light & turn on your headlights, does anything happen?
Old 04-09-2013, 12:13 PM
Thanks Akila
looks like there are not any alternatives - guess I will have to try and get the shroud welded - unless I am reading that wrong?
Old 04-09-2013, 12:21 PM
From the chart looks like you could use any 245 mm fan shroud from 75-89. IIRC the most concern seems to be the diameter. I was sent this chart because I wanted to find Aluminum pieces to polish. Give Ed Baus on the board a pm.
88' 930
Old 04-09-2013, 12:38 PM
After 84 its the depth of the alternator using the large Paris Rhone.
The pre 84 used a smaller alternator (depth wise) so there is more base metal to the bottom of the alternator seat
Old 04-09-2013, 04:43 PM
E-85 sippin drunk
turbobrat930's Avatar
You can always buy a repo from Vertex auto.... They are made from Al, instead of Mg... I have heard good and bad stuff about the fittment of the part.... but its new, and about the same price as a good used one, and its Al, so it can be welded on if need be
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-35RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 04-09-2013, 06:01 PM
Go for the vertex
I had the same problem with my 88 turbo...
Call vertex and tell them what you have and they will send you the right one.
I looks good and fit right into the spot with no problem.
Signature Phrase " CATCH ME IF YOU CAN"
1988 Porsche 930 "Squerly" Built by "Porsche Doc"
1974 Porsche 911 (2003 - 2012)
2000 Boxster S (2006 - 2008)
Old 04-09-2013, 08:37 PM
I had the same problem with my 1988 spent two weeks looking for magnesium rod to weld it and i would have had to buy 20 lbs then build a jig and machine it out. So I bought the aluminum one and it fit just about spot on with a little sanding and filing. I then primed and painted it black then painted my fan red to match my car. Looks good.
I was a little worried about the aluminum corroding with salt spray
Old 05-07-2013, 10:33 AM
The Vertex guys will take care of you, if you don't mind aftermarket stuff.
Old 05-07-2013, 11:29 AM
beancounter
jwasbury's Avatar
Vertex. Paint to your preference (mine is Zinc Chromate - an "aviation" look). Done!
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 05-07-2013, 12:15 PM
