xbmwguy's Avatar
here is what i am doing with 10-an ends
Old 04-12-2013, 09:34 AM
Ken911's Avatar
oh ok that looks good does any one use any of the regulators that come with a 3.2 intake? or is it just more stuff to sell here?
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
05 Cayenne S lapis blue
Old 04-12-2013, 10:29 AM
jsveb's Avatar
Xbmwguy, are those fittings MIG welded to the fuel rails.
Just wondering, because I have some rails that was cut by PO and also some an fittings...and a mig welder
Jesper
Carrera 3.0 1975
930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer
www.stauningwhisky.dk
Old 04-12-2013, 10:50 AM
xbmwguy's Avatar
ken those wont work for our application. dmatera can hook you up with fittings, hose, injectors, andrising rate press regulater. yes it was mig i think
Old 04-12-2013, 02:05 PM
If Bruce did it, more likely tig welded.
Tungston inert gas with a stick instead of wire feed mig.
Old 04-12-2013, 02:19 PM
Chain fence eating turbo
The only reason to replace FPR is if you went with a rising rate reg. If not, the 3.2 FPR is just fine for boost.
I used it both ways with a Protomotive rising rate that uses the stock 3.2 FPR to work. It's a simple large diaphragm with a piston that pushes on the stock 3.2 FPR once in boost.
Pretty trick.
Old 04-12-2013, 04:25 PM
TurboKraft's Avatar
If you are re-welding with AN fittings, it is likely easier to use an AN regulator. Otherwise you're doing AN on one end and M16 to the 3.2L regulator -- fine, but more expensive special order fittings.
We use a larger Aeromotive A1000 for big HP fuel and/and ethanol applications, and it has 6AN/6ORB adapter fittings.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Ken911's Avatar
yeah i already got injectors and an inter-cooler and some pipes and fittings from him
Old 04-12-2013, 08:36 PM
You need to remember whatever you find out they support on gasoline that E85 uses about 30-35% more fuel. I used to have a jig for the billet ones you are requesting, but stopped making them. You might try Marco Manzie at Billet Design
Old 04-13-2013, 07:16 AM
nocarrier did a good writeup for adapting AN fittings to the stock lines and rails.
Carrera Intake Fuel Line Update For My Efi Conversion
1987 GP White 930
1977 Ford Bronco
Old 04-13-2013, 03:06 PM
Ken911's Avatar
Thanks!!
Old 04-14-2013, 09:10 PM
Not much info but I found these.
Porsche 911/911 Turbo fuel rails Part No. 0447
1987 GP White 930
1977 Ford Bronco
Old 01-24-2014, 01:55 PM
