which clutch disc to use?
I'm looking for some input on which disc to use? I'm putting my 500+ HP engine back after winters upgrades. I had a Sachs organic disc, which I installed new with a KEP stage 1 last year. I have a Sachs segmented disc, which I'm trying to decide whether to install. Any one with any comments/experience on the segmented disc. Mostly country driving, at WOT.
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Old 04-23-2013, 03:36 PM
This segmented disc is also thicker, spec at 9.65mm as the organic disc is 9.45mm. Will this affect pedal press. any? I see some of the Sachs discs spec out at 8-10 mm. Philip
Old 04-23-2013, 04:06 PM
Scottsdale Arizona USA
Hello, the disc pictured is a Centerforce unit. Base Sachs parts but with upgraded features. These are set up and sold only with the matching pressure plate covers. The dual friction tech is full face lining on one side w segmented carbon kevlar on the other. There are updates to the pressure plate too which increase clampload. Great for street but also great for track use.
The bullet proof top dog clutch for the 930s are the Centerforce DF255255 (low profile cover)
I would recommend using a stock disc with the KEP pp (also great clutch but stiffer pedal). Yes it is important to have proper disc thickness!!
Day @ Euro Parts West, LLC, Scottsdale, AZ USA // Automotive Part Connectors & EPW MODE : Motorsport Design
+1 (844) URO-PART // mode@europartswest.com
Old 04-26-2013, 02:22 PM
Yea, I ended up putting the organic stock disc back in. I felt kinda guilty breaking up the clutch and PP. Maybe next time I'll use the Center-force setup. Thanks Philip
Old 04-26-2013, 07:57 PM
