EFI EDIS Ignition Chrysler Coils
Hey Guys
Just wanted to check to see if anyone is using chrysler coils packs with there EDIS
ignitions? I plan on going Megasquirt 2 with Dual EDIS controllers. Last fall I purchased a brand new set of wires from Richard Clewett for my twin plug Electromotive HPV1 ignition. I want to reuse the the wires but don't want to have to cut the ends to fit the Ford coil packs. The wires will fit the Chrysler and GM coil packs.
Any thoughts on this would be appreciated.
John
1988 Porsche 930 Targa - 3.4L Twin Plug Motor, DC 13 Cams, Supertec Head Studs, ARP Rod Bolts, Port and Polished Heads, Garretson Andial Intercooler, GSX 61 BB Stage 5Turbo, Tial F46 WG .8 Bar Spring, PowerHaus Headers, Rarly8 Dual Tip Muffler, MS3 Pro EFI conversion, 57lbs. Cobra Injectors, Center Force Stage 2 Clutch , Rebuilt 4 Speed with LSD.
Old 05-05-2013, 05:40 AM
There is some mention of Chrysler coils with EDIS here: EDIS Crank Fire System - Ignition and Electrical - HybridZ
You may want to search around on the MS forums. I'm sure someone has made it work but maybe not specifically on a 930.
1987 GP White 930
1977 Ford Bronco
Old 05-05-2013, 06:01 AM
Thanks Willtel
Old 05-05-2013, 06:05 AM
Not sure if they will work with your plug ends but there is a seccond generation edis coil pack that uses a different plug end. Also, the newer edis coil packs are flat on the bottom for easier mounting.
Old 05-05-2013, 02:19 PM
Old 05-05-2013, 03:02 PM
