Dogman 930
smoke
930 smokes like a brush fire on start-up and clears then thats it , this normal ?
Old 05-15-2013, 05:14 AM
Smart quod bastardus
fredmeister's Avatar
No sounds like the compressor seals may be blown on the turbo.
Mine did that only after hard running on the track upon startup after sitting between sessions.
Check down inside the compressor housing inlet to look for oil and oil inside the intercooler. This would confirm trouble.
Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 05-15-2013, 07:28 AM
Norm K's Avatar
Classic symptom of worn valve seats.
Engine cools, parts contract, oil seeps past the seats and into the cylinders. Start the car, oil burns off, parts expand, no more smoke. Rinse and repeat once the engine cools down.
If the Army and the Navy
Ever look on Heaven's scenes;
They will find the streets are guarded
By United States Marines.
Old 05-15-2013, 10:16 AM
All of the above and it may be worse if the oil level is at the top of the "safe" range on the oil tank dipstick. Alot worse if it's overfilled.
When the oil level is towards or at the bottom mark on the dipstick it may not be as bad... if you're lucky.
Old 05-15-2013, 11:08 AM
Dogman 930
thanks everyone ,
Old 05-18-2013, 12:43 PM
