Tach needle stops as outside temp increases
My tach works flawlessly until the outside temp reaches about 80 degrees and then the needle will rev to 5K but will not go beyond this point... when revs fall below this point the needle shows the correct RPM... Since it is heat related is it the needle within the dial face ( heat deflection/ warping ) or is it possibly electronics driving the needle? Ideas please and thanks.
1987 930 -Guards Red
2001 740I sport Blk
2011 F-150 supercrew Blk
2014 X3 2.8 white
"What goes around comes around..."
Old 05-19-2013, 05:07 AM
Crotchety Old Bastard
RarlyL8's Avatar
It can be both. The materials can warp with heat causing mechanical interferance and the aging electronics can also malfunction when the cockpit temp spikes. Typically once you are traveling down the road and air is moving through the cockpit the needle will unfreeze.
To determine which it is you can carefully remove the glass.
Old 05-19-2013, 07:00 AM
My '87 is doing the same thing. I haven't had a chance to troubleshoot it yet but I'm leaning towards interference with the glass.
Old 05-19-2013, 04:38 PM
beancounter
jwasbury's Avatar
My '79 had a sticky tach needle and it was this^^
I disassembled the unit, flipped the lens over and reassembled...problem hasn't returned in years.
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 05-20-2013, 05:19 AM
