930 CIS from 86?
I recently acquired some "parts" from a track car. I was surveying a throttle body and noticed what looked like a tps. Does anyone know what this is? It is not on my 78 930. I have also discovered this motor was andial equipped. I also noticed there are some differences in the manifold and WUR. I didn't realize there were so many differences from a 78 930 CIS.
The fuel head has also been opened up, I am told. Is there a way to determine by how much? Injector flow test?
John- I blame and thank the longhood boys of Austin
84 911 Carrera w/ 930 t/p,efi'd,dizzy free,HFS turbo[/COLOR], 78 930 RoW no option sunroof coupe, 64 Corvette roadster, 71 911T, 73 911E, 67 Bronco survivor. 71 FJ40, 2001 Boxster
"Illegitimi non carborundum"
Old 05-23-2013, 11:03 AM
M5guy's Avatar
"Andial equipped..." What Andial equipment is on your engine?
SR
86 930
x: 62 356, 64 356, 76 930, 84 911 Targa, 85 ROW 911, 00 996, 07 Cayman S.
Old 05-23-2013, 11:20 AM
The later CIS cars have a TPS of sort but it doesn't measure a linear curve like the ones most of us are familiar with. It is more like a 3 position sensor that measures closed\half\full throttle.
I can't remember what it is for but I'm sure someone smarter than I will chime in.
1987 GP White 930
1977 Ford Bronco
Old 05-23-2013, 11:39 AM
andial
Sorry to be to vague. It only has the fuel enrichment processor and frequency valve in the parts I bought.
I had another car that had the f/e and the dial of death. That must have been popular back in the late 80's
Old 05-23-2013, 12:00 PM
The throttle position switch is part of the lambda emissions system switching it into open loop mode to allow a richer mixture at full throttle. Not sure what effect it has at medium throttle but probably changes the frequerncy valves return line percentage.
I removed all the lambda crap on my '87 and have wanted use it to trigger a relay that disables the AC clutch at full throttle but havn't gotten around to trying that.
Are you going to use it or sell it? I'm curious what you got it for.
Old 05-23-2013, 12:12 PM
mark houghton's Avatar
I can see the Andial enrichment freqency valve, with of course is useless without the computer controller that goes with it. As Jim said, the TPS is for the Lambda system.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 05-23-2013, 12:37 PM
Jim,
This stuff came with a bunch of other 930 parts like a scavenge pump, turbo, i/c, engine tin, w/g, etc so it's hard to put a value on the lambda system. It seems any of that 930 stuff is getting harder to find and isn't coming up that frequently to gauge the market price of something. I am going to figure what I am going to keep for back up for my 930 and sell the rest to pay for parts for the 78 like window gaskets and so on.
Mark,
I do have the controller. It came with the jetronic lambda system. You are right the f/v would be useless and even better to have the controller than the f/v imho.
John
Old 05-23-2013, 01:19 PM
Unless you bolt an additional injector controller onto it and use it to trim CIS pressure under boost - like Thiery and Stup did.
Which was my intention when I bought the Split Second AIC1, until the debacle of Unwired killed all my appetite for messing with CIS...
'77 S with '78 930 power and a few other things.
Old 05-24-2013, 06:24 AM
