T77911S's Avatar
i can pull a vacuum on it and it holds all the way thru. i have questioned the DOD since i got the car. the knob turns very easily. i had it out once but could not really tell anything as far as does it work. i will pull it again, just dont know when
how much should it add to the boost? if i have a .6 spring, should it go to 1bar?
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 06-14-2013, 08:37 AM
sjf911's Avatar
Manual boost controllers work by reducing the pressure seen by the WG so you need to do a pressure check before and after the DOD not a vacuum check.
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 06-14-2013, 09:11 AM
T77911S's Avatar
i thought mine took a portion of the boost pressure and put it back on top of the diaphragm to add to the spring tension. this was just my quick analisys of how the system works.
i may use this line to hook up a temperary gage to see what my boost pressure is to the WG vs in the manifold. i want to see what the pressure does above the throttle plate vs below
Old 06-14-2013, 09:18 AM
