Update After Modifications
Okay, after installing headers/exhaust, air intake, inter cooler, new k27/29 turbo, Tial 46mm (1 bar spring), Patrick Motorsports Clutch and LWFW, Leask WUR; keep in mind that this is the first run out of the box, still needs some dialing in; she produced 352 rwhp at 4800 rpm and 436 ft/lbs at 3400rpm. She is a little rich below 3500, at 4000 rpm AFR is 11.44 (ideal) then she starts to lean out to 12.75 AFR at 5000rpm (shut her down after that).
I'll try to post up the dyno sheet later today. I think we need to work on the timing (too much torque?) and add fuel above 4500rpm to keep her under 12 AFR. We also need to dial it down (fuel is at 10 AFR or so) below 3500. I think if we dial it in, we can achieve 375 rwhp/400 ft/lbs. Any thoughts? Motor is a stock '79 3.3, all new hoses, oil cooler, spark plugs, plug wires, etc, etc. http://forums.pelicanparts.com/uploa...1370890449.jpg |
I believe Porsche did use RWHP figures, so the USA 265-280HP depending on the year was RWHP.
Forget the numbers (other than AFR)- how does it drive? I'll bet you've transformed the car with all the right mods. |
Interior shot http://forums.pelicanparts.com/uploa...1370975951.jpg |
That Fabspeed is some good looking stuff you have there.
Prrrreeeetttycool!
Impressive torque that early... was the dyno properly calibrated? If so, congrats! |
How's it sound?
How come the torque and hp curves dont intersect at 5250rpm point? They should cross at that rpm unless you altered the scales on the graphs somewhere between the two. Not trying to be a ball buster but this is confusing and just wanted clarification. Those are impressive numbers for the changes you have listed. Fred |
HP = (Torque x RPM) / 5252
At 5252 the TQ and HP values should be equal. In the graphs above, it appears the values are the same at 5,250rpm. It looks wonky because the scaling of the left axis and right axis are different. |
Ideally, a 1:1 drive ratio. For a 930 4-sp, 3rd is closer to 1:1 than 4th is.
I know running a higher gear gives you more time to get load and high boost on the engine, but do not understand the importance of 1 to 1 ratio in the tranny. Fred |
From Wikipedia: A gear train can be analyzed using the principle of virtual work to show that its torque ratio, which is the ratio of its output torque to its input torque, is equal to the gear ratio, or speed ratio, of the gear train. This means that the input torque T<SUB>A</SUB> applied to the input gear G<SUB>A</SUB> and the output torque T<SUB>B</SUB>" on the output gear G<SUB>B</SUB> are related by the ratio <DL><DD>http://upload.wikimedia.org/math/d/4...74a6e6cc97.png</DD></DL>where R is the gear ratio of the gear train. |
Thanks Fred |
| All times are GMT -8. The time now is 03:13 AM. |
