Dan Jessup
Needing rear window wiper arm/blade...
previous owner removed to make room for aftermarket AC... I've junked that system and now going for originality points. Please contact me if you have, danjessup "at" me.com
River Rat
I have one from 86 930, what parts are you looking for?
1986 930 - K27-7200, Andial Intercooler, Tial Wastegate, Electronic Boost Controller, B&B headers, Bodart Zork, Leask Adjustable WUR, Full Elephant Racing Suspension w/Adustable Spring Plates and Von Shocks, Wevo Transmission Mounts, Fuel Safe Fuel Cell, Forgelines (9"/11"), Hargett Shifter, Innovate AFR, Cobra CF Seats, DAS Rollbar, Coleman Floating Rotors, Lightweight Interior, Forgeline 17" x 9"/11", 2800 lbs. |
i have an arm if needed
Dan Jessup
Still looking for an early arm & motor if anyone is willing to part with. PM or EM is fine. Thnx.
dan i still have the arm but no motor
Banned
Have you checked eBay? I recently sold the complete rear wiper set-up for around $100 . . . If I remember correctly, there are quite a few of those to choose from on there (and not all of the sellers have outrageous prices listed).
Happiest when Tinkering
I think I have an early arm and motor if you have part numbers let me know
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go! 76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3 76 Blazer also restored by me |
Boost Abuser
I will be removing a complete set up from an 84 930 this weekend.If this will work I bet we can talk the owner out of it. Let me know if I can help.......Ben
"I can't drive 55" |
The early tail 75-77 rear wiper arms, and wiper trans are different from the 78 on wiper assembly. The motor locations are different due the the intercoolers on the 78 on turbo's.
Both early the style arms and the thru-deck trans are NLA as they use a pinch bolt to secure the arm, while the later arms use a bolt on top to secure. The early arms are also a bit thinner ( fyi the pinch bolt style arm is avaiable for right hand drive cars 90162861200) The early style brackets are still availble as is the mounting hardware and rod. The wiper motors are inter changable. You can use the later trans but it will need to be modified. You will need to shorten the trans that goes thru the deck lid as its too long. Additionally the later trans is a bit "thicker" in diameter and just barely fits thru the early style deck lid. ![]()
1983 911SC 1977 930 Turbo (again) 2018 GTS 2023 Audi A4 '74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone) |
Dan Jessup
As always - thnx for the posts. I heard because of the intercooler that they were different on the early Turbo's... and since ill be doing a repaint i have sometime to find an erly setup so i wont have to modify anything. PM or EM me if you know of or have.
Were rear wipers available on the 911 S and Carrera 3.0 of the same vintage? Would it be the same wiper mechanism as on a 3.0 Turbo? I'm assuming that mine was removed by a previous owner for some unknown reason, and I'd like to replace it too.
2012 911 Black Edition Cabriolet 2008 Cayman S Grey on Black - flooded, written off 1977 930 Turbo Carrera Black on Red #411 1987 951 Black on Black - sold to make room for the 930 1972 911 2.7 - I regret selling her every single day.... |
The early rear wiper was the same for all models. I found this out when I was researching parts for mine. This when I realized I could buy a pinch style early wiper arm for a "right hand drive" car which is still available from Porsche thru pelican. The orientation is different but easily solved with a little heat, bending and respray.
All of the other parts are still available. Motor, bracket, connecting rod, and hardware. Even the wire harness. The only part NLA is the early wiper transmission that goes thru the deck lid. If you can score one then you are in business. If you can not get the early transmission, then you can still you a later style, but it still needs to be modified. Otherwise it will stick out of the deck lid too much. Then you can use the bolt on arm which is easily available.
I don't know if you got my pm I am having Internet issues please let me know. Oh by the way the bottom pic is what I have.
