CaptainCalf's Avatar
930 transmission mounts/cushion replacements
I decided the 1987 tranny crossmember rubber cushions need replacing even though they are not made to be easily replaced. You may have noticed that our 930 crossmembers have the rubber mounts pressed in and not bolted on like others, so there aren't many options when it comes to replacing them. I found two viable options:
1- send the whole crossmember off to Wevo to be cut and re-welded with new semisolid cushions or order their kit and do the welding yourself.
2- order a special set or 901 type semi solid cushions from Rebel Racing and do the press work yourself.
I decide to go with option two and they worked great! While I was at it I also upgraded the motor mounts too.
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD
1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD
2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha
Old 06-12-2013, 07:00 PM
I was not aware of this option. It looks much more convenient than sending to Wevo.
I will look into this, as well.
Emery
1988 930 coupe - Silver Metallic
3.3L w/GT35R, B&B Headers, RarlyL8 muffler, TurboKraft IC, Tial WG, tecGT based phased sequential EFI & ignition, Wevo shifter/coupler, ...
Old 06-13-2013, 02:22 AM
xbmwguy's Avatar
hey cap is your shifting crisper now? i am thinking of doing same
Old 06-13-2013, 03:44 AM
Very cool. After running Wevo blues in 911's for years I've been trying to figure out what to do about the 930 mounts. Great find!
Old 06-13-2013, 04:09 AM
Yes, that's why I posted it up cuz I know it's been an issue for folks for a while and this fix takes all of 30 minutes
Old 06-13-2013, 04:39 AM
Yes, crisp and clean and it actually feels like the power is laid down better. I guess cuz the mushy cushions absorbed/robbed some in translation between on and off throttle...
Also, the blues are 40% harder then stock, but not harsh at all and I'd recommend them highly!
Old 06-13-2013, 04:42 AM
Thanks & glad to help you guys out. This forum has helped me so much I'll never be able to repay my debt, so I'll just keep trying
Old 06-13-2013, 04:43 AM
Smart quod bastardus
fredmeister's Avatar
how hard was it pressing these in yourself?
were you able to do it in bench vise or did you use a hydraulic press?
Thanks for the post.
Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 06-13-2013, 01:16 PM
Fred
Easy as pie if you have a 10 ton press, but watch for that flying 18 mm socket that you use to push with:-)
Old 06-13-2013, 01:20 PM
Did you have to do any cutting on the 930 crossmember or just rip out the old mounts and press in the new mounts? I thought the mounts were encased in the crossmember (have not been under there to look in a few months ...)?
Emery
Old 06-13-2013, 01:52 PM
No they will press out and new ones are 2 piece so they go in w/o press...
Old 06-13-2013, 01:57 PM
