Banned
Originally Posted by Hirevtuner View Post
x2
So your 7006 leaks as well?
Old 06-14-2013, 02:59 PM
jsveb's Avatar
Chris,
Thanks for taking the time to explain these things. It is greatly appreciated.
Perform a simple scavenge pump test. The process has been covered many times on this forum, but the short form is this:
* allow the turbo to drain into a container
* extend the scavenge line, stick the free end into the container
* start the engine
Oil should be scavenged out of the container faster than the oil drains our of the turbo, at all rpms.
We have seen used pumps work at idle and not at revs, and vice versa.
It is not uncommon during a turbo swap to have to remove the scav pump an install new seals (cover, shaft), as well as replace (or thoroughly de-carbon) the oil line into the turbocharger.
TurboKraft sells new braided PTFE/stainless oil feed lines for the 930s to replace the stock ones that leak where crimped, but the check ball is retained at the case's oil fitting, and there is no restrictor used with 3K-Warner or other journal bearing turbochargers.
If the pump is good, it's your turbocharger.
Old 06-14-2013, 05:25 PM
klefroid's Avatar
Thanks for the great information!
So I tested the scavenge pump like described here. It sucks a bit but it does not follow up. after 30 sec I have my container full. 2 liters of oil. when I put my finger on the line I can feel it sucking but not much. So past Saturday we changed to the original turbo and all is fine... but can the old one handle more pressure the a K27?
BUT I have to say that I did it not the right way. I did a test without the turbo, so I just used the lines... I will do a new test when I got some more time to spent...
Is there a way to check if your turbo is an original KKK?
even I do not trust that turbo anymore ...
Again thanks so far for helping me out guy's!
Old 06-18-2013, 01:20 PM
klefroid's Avatar
* start the engine
So if the scavenge pump is bad?
Do you sell what I need?
Would be great!
BTW that turbo adapter I bought from you worked very well... but still it's a waste of money right now
Old 06-18-2013, 01:27 PM
TurboKraft's Avatar
Don't despair, we have seen this same thing when installing a brand new C2T K27-7200, genuine 3K-Warner right out of the box.
Our operating theory is this:
The old turbo is slowly coking up, restricting oil flow. Same oil pressure and volume in, less and less out.
At the same time, the scavenge pump is slowly losing efficiency, seals hardening, sucking less oil per revolution.
Whenever we install a new journal bearing we also
* replace the stock oil supply line -- it is likely coked up some and you don't want a chunk of carbon to come out and block one of the tiny oil holes in the bearings
* rebuild the scavenge pump with new seals & gasket, plus air injection pulley housing seal & gasket
We frequently sell these in kits to people who call/email with this exact same problem, and most of the time a pump rebuild cures it.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 06-18-2013, 01:35 PM
klefroid's Avatar
I will sent you an e-mail and send me the stuff I need! thanks for your help Chris!
One more thing, if it would be the scavenge pump, would this damage the turbo or is it still usable?
Old 06-18-2013, 01:42 PM
TurboKraft's Avatar
Unless you've put a lot of kilometers on it with it spitting oil out the exhaust, coking up the turbine side (heat shield, wheel), the turbo is likely undamaged.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
Old 06-18-2013, 02:02 PM
klefroid's Avatar
Ok, it just had it on idle....
BTW, I've send you an e-mail.
Old 06-18-2013, 02:10 PM
