Crotchety Old Bastard
RarlyL8's Avatar
RL8 Outlaw System
We already have a zork/tailpipe system called the Outlaw. It is simply a muffler bypass pipe that plugs into our modular line-up. The Outlaw pipe can be swapped out for a Hooligan or Street Muffler and used with any tailpipe configuration.
This one is a GT3:
Here is a dual outlet Outlaw:
Old 08-17-2013, 09:22 PM
Turbofrog
smurfbus's Avatar
Any news on butterfly Zorks?
79 930: HX40S#16, MS3pro+ID1000+044+E85, Ignition: 123/TUNE/MSD6A, True split BB, 2*turbosmart38
Old 04-29-2014, 09:58 PM
Mr. C
SAY - 642's Avatar
Nifty, Brian
" Mr.C "
Six = Sex
Old 04-30-2014, 11:09 AM
RarlyL8's Avatar
Not sure what is meant by butterfly Zork. I've been working on a 930 active exhaust for years now and believe this latest design will satisfy all the criteria. Building an affordable valve that will live in that environment has proven quite a challenge.
Old 05-01-2014, 04:59 AM
Turbofrog
smurfbus's Avatar
I would be satisfied even with a bulk wire operated flap. Do you have any price set for your unit?
Old 05-01-2014, 06:54 AM
RarlyL8's Avatar
Not yet, we have to test this final version then work on the cost.
Yes there are all sorts of valves out there that you can use. DIY guy can simply swap them out when they seize. Ours needs to last years to avoid the hassle.
Old 05-01-2014, 09:24 AM
Tilikum Turbo's Avatar
Is there a set-up with the Zork which makes the car look like stock?(exits at left side of valance?)
1983 911 3.3L Turbo(YES, I know the turbo badge is on the right...had to be different!)
1996 Toyota Corolla(der 'clapper')
Old 05-04-2014, 07:34 AM
RarlyL8's Avatar
Yes, our systems are modular so you can pick which muffler (or bypass) to go with which tailpipe(s). The muffler bodies can be swapped out if you wish to change to a different sound level and the tailpipes swapped out for a different look.
Old 05-04-2014, 02:13 PM
