peter3216's Avatar
fuel
is 100 octane Leaded gas OK for our cars ?
1985 row 930 turbo
Old 06-18-2013, 07:36 AM
It would be perfect.
Old 06-18-2013, 08:44 AM
Brando
quattrorunner's Avatar
Where you get that?
Turbo powa!
1977 911s. it's cool
Old 06-18-2013, 08:57 AM
9Thirty's Avatar
I know where to get 100 unleaded.
Old 06-18-2013, 09:32 AM
They love it. Just make sure the cat or anything like that is removed before using it.
Qauttrrounner= Usually it can be found near a stock car track, or a road race track and small airports that have old planes around. I have three stations within 20 miles from my garage with 112 leaded which i mix in some cars with pump 93. The really high HP & boost cars I use it full strength if i am planning some track time. One side benefit of living in WI and near Road America. Come on over and live here in the summer, winters are not much fun though. You can also order 112 or 117 octane in 55 gallon barrels if you have a good place ( and the nerves) to store it.
Anthony @ Voitureltd Bayside WI.
Old 06-18-2013, 10:58 AM
Garage Queen
PorscheGAL's Avatar
Peter3216,
Thanks for posting this question. We have leaded race fuel sold near our house and we have considered buying it. Our only concern was having an LM-1 for AFR monitoring. This is what Innovate says about leaded fuel with the LM-1.
"Wide band oxygen sensors like the one shipped with the LM-1 are designed to work with unleaded gasoline. Using them with leaded gasoline will significantly reduce the lifespan of the sensor. The reduction is directly proportional to the metal content of the fuel. In most cases, a wide band sensor will provide accurate measurements somewhere between 50 hours and 500 hours with leaded fuel."
I don't know if you have an AFR sensor, but just wanted to let you know about this issue. It is a little crazy that the times are "between 50 hours and 500 hours". Hopefully, if you have LM-1 style sensor, you get the 500 hours!
Stephanie
My minions:'86 911 Targa 3.4, '87 930, '05 Lotus Elise,
'19 Audi RS3, '13 Focus ST, '16 Focus RS
Old 06-18-2013, 11:21 AM
Boost Abuser
LOWFAT's Avatar
I usually run a 50/50 mix of 93 and 110 leaded in my 86.My car really loves it, and the smell while idling is great.I am also running a LM-1 with no ill effects for the last 4 yrs.Once a year I pull the sensor from the exhaust and clean it off with a little fine grade steel wool and re install.
"I can't drive 55"
Old 06-18-2013, 12:23 PM
peter3216's Avatar
i was told there is a little airport near my summer place that has the leaded gasoline i did not go yet, wanted to know if it was OK before i when .
They will not let anyone put it in the car i have to bring a gas container.
I do have an LM-1 thanks for that info.
1985 row 930 turbo
Old 06-18-2013, 05:11 PM
Air Medal or two
afterburn 549's Avatar
make sure you chek Av gas for water..
D troop 3/5 Air Cav, and 162 AHC- Can Tho
For those who have fought for it,
freedom has a flavor the protected will never know.
Old 06-18-2013, 05:42 PM
j930's Avatar
if you live near a airport they have 100LL 100 low lead. i would not be to concerned with finding water in it unless you are in a area with some old fuel tanks. most all of the aviation fuel is filtered for water as it comes out of the holding tanks in the ground. in 10 years of flying i have never even found a drop!
i have considered running it in my 930. most all airplanes are air cooled and the motors seem to like it. you do have a issue with lead building up on the spark plugs but that is when you are running it all the time.
anyway out there know or have had experience running 100LL in our cars?
84 930 Slant
15 Sonata 2.0T
08 Ram 1500
15 Ram Eco Diesel
Old 06-18-2013, 06:56 PM
Chain fence eating turbo
Just remember 100LL is still leaded gas in case someone reads this running a cat.
Old 06-18-2013, 07:16 PM
TurboKraft's Avatar
And if running an O2 sensor.
It's not the outside (bulb tip) of the sensor that builds up and ceases working, it's the sensing device inside.
The Dynapack dyno uses a Motec PLM to monitor Lambda, and we see brand new sensors die within a day's dyno session on old V8s running leaded racing fuel.
Low lead will contaminate the O2 sensor and skew the readings, just not as quickly as leaded fuel.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 06-18-2013, 07:22 PM
Tilikum Turbo's Avatar
Unless the motor 'pings' on a diet of 91-93 octane, does running anything higher really provide any benefit(unless timing is changed)?
1983 911 3.3L Turbo(YES, I know the turbo badge is on the right...had to be different!)
1996 Toyota Corolla(der 'clapper')
Old 06-18-2013, 07:42 PM
Smart quod bastardus
fredmeister's Avatar
Anyone ever seen mail order 5 gallon portions of 100 or 110 unleaded anywhere? This might be more viable for storing than a 55 gallon drum.
I heard this was available somewhere before at a track event but never heard where from.
No local hot rod stations around here, and dont like paying $9 per gallon at the track.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 06-19-2013, 10:03 AM
I've seen the 5 gallon containers of high octane gas at a local auto parts store and it was more expensive than $9 per gallon. I don't remember the octane or exact price but it was up there.
Old 06-19-2013, 10:16 AM
9Thirty's Avatar
There is a BP 5 miles from me that sells 260GT right out of the pump, it used to be 7.29 a gallon, now it's 9.39!!!
Old 06-19-2013, 11:37 AM
Tobias A
Toby930's Avatar
Send a message via Skype™ to Toby930
$9 is about what we pay for a gallon of regular 91 pump gas here in Sweden
Wish we could have some really high octance gas in our pumps here. And ethanol free would be nice too :-/
Old 06-19-2013, 02:51 PM
