damaged rim
I just had a new set of tires installed, and maybe by coincidence, or maybe the tire jockey clamped the rim improperly, but the rim is split right where it has a 90* bend. I would like to find a used barrel if possible. They are custom made 17" fuchs, with 20 bolts. The inner barrel is nearly 7.25 inches as seen. Any help appreciated. Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Old 06-23-2013, 03:26 PM
found a barrel...
and thanks to those who suggested it may be a broken seal. I will have a more detailed look at it tomorrow, and hopefully that's all it is. Philip
Old 06-23-2013, 06:18 PM
If it is a bad seal, strip the tire and use silicone to seal the spit. I can't remember exactly which silicone, but it was a silver one.
Bryan O.
77 930
88 Carrera cab
14 535i M Sport
Old 06-23-2013, 06:27 PM
It's more than likely a bad seal. I had this happen when I put together 3-piece wheels and the silicone inside didn't cure properly.
If you need suggestions on how to do this yourself. PM me and I'll do my best to help.
Old 06-24-2013, 08:00 AM
cracked rim
Well it turns out to be a hairline crack in the rim. I found a used barrel... Philip
Old 06-24-2013, 04:39 PM
