B+B B+B is offline
B+B's Avatar
E-85 Fuel Requirements
I'm curious, what is required to run alternative fuels or Higher Octane in our turbo engines.
Do you need a special gas tank?
Larger Injectors?
Improved Fuel Lines?
What other required bits are needed in a EFI set-up, to run e-85 and turn up the boost?
Old 07-10-2013, 04:11 PM
Ingenieur
Porsches have steel tanks, with a plastic sump in them.
(14.7/9)*100 = 163%.
Bigger fuel lines, PTFE. Anything will work with ethanol, for awhile. PTFE will work forever.
Old 07-13-2013, 12:59 PM
B+B B+B is offline
B+B's Avatar
Thank-you Speedy Squirrel.
I'm having all new everything built. So might as well modify, while the engine is out.
Old 07-13-2013, 01:05 PM
