tops911's Avatar
surging and loss of power
Hi all, yesterday when driving when I hit about .5 bar the car would surge and sorta "hit a wall" and not rev any higher, I think it was around 4500 rpm. The car did it a couple of times, the one time I was watching the AFR gauge the AFR was 15 or so, I immediately backed off every time this occurred. Today it ran a little rough but the AFR was normal, 11, at .5 bar and reved to 5000 before I let off the gas. Does this sound like a fuel pump issue? The car ran fine for 600 miles when I picked it up in Dallas. The ignition system is all new within the last year and half, I did order a new non-resistor rotor from NAPA, just in case. I don't have any of my tools to do any kind of proper diagnosis, the household goods get delivered Friday.
Thanks Frank
1982 930, K-27, BL adj. WUR, Rarlyl8 Headers and Hooligan muffler, PK CDI, 22 and 30mm torsion bars, poly bronze bushings 30mm raised spindles and custom valved Bilstein shocks (by Elephant Racing), monoballs front and rear (by Rennline), Alton 17" Fuchs, Fred Cook fuse panel
Old 07-17-2013, 07:42 PM
jsveb's Avatar
A hose has popped off. Maybe a signal hose for bypass valve etc.
Jesper
Carrera 3.0 1975
930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer
www.stauningwhisky.dk
Old 07-17-2013, 09:29 PM
