Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Ken911's Avatar
yeah i Just hope they look ok when i'm done though. I'm getting better though so we'll see. When i welded the bungs the inside welds that had been ground out already cracked and i had to reweld them like GJF had warned me about.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
05 Cayenne S lapis blue
Old 02-27-2014, 05:43 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #261 (permalink)
Chain fence eating turbo
Beauty of metals is you can always add and take away material unlike wood working.
Old 02-27-2014, 06:20 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #262 (permalink)
Ken911's Avatar
yes so true
Old 02-28-2014, 08:46 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #263 (permalink)
Ken911's Avatar
Some more new bling arrived today my wastegates showed up.
Old 03-25-2014, 04:00 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #264 (permalink)
Porsche 935's Avatar
Nice set up. I have been running EFI for 24 years on twin set up. But mine are high butterfly manifolds. Injectors are at the base spraying at the valve. What kind of linkage will you be using?
Old 03-27-2014, 04:22 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #265 (permalink)
Ken911's Avatar
I have this set up
Linkage kit Flat - Porsche - Jenvey Dynamics
Old 03-27-2014, 04:40 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #266 (permalink)
Ken911's Avatar
Well our refueling outage is over so I finally have been able to get back to work on the car. I finished the intake manifolds. This is them getting the final cleaning before i drop them off at the powder-coater.
Old 04-30-2014, 03:45 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #267 (permalink)
Do your throttle bodies have a port for the map sensor reference?
Old 05-01-2014, 04:01 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #268 (permalink)
Car guys uses for a dishwasher
Thats great!
Good luck with your motor build Ken, it's looking good.
Old 05-01-2014, 04:43 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #269 (permalink)
Happiest when Tinkering
gsmith660's Avatar
Refueling outage? Which one I am on my 4th of the season
Old 05-01-2014, 06:41 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #270 (permalink)
Ken911's Avatar
I'm at Turkey point we just finished unit 3. I work for FPL so I only do the ones here in Florida. the two here and sometimes i travel up to fort pierce for Saint Lucie outages if they don't overlap. Next one is in the fall
Old 05-01-2014, 10:19 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #271 (permalink)
Ken911's Avatar
Thats great!
Yeah when I was married the wife used to b*i*tch about that a lot. Fortunately Thats no longer a problem. Thanks it's coming along really slow as funds allow.
Old 05-01-2014, 10:21 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #272 (permalink)
Ken911's Avatar
Nope thats why I had to make the manifolds with two ports. All the premade ones I could find only had one vacuum connection. One for idle bleed. the other for everything else. Brakes, map sensor, vacuum signal for boost controller. I'm not sure though if I will be needing a map sensor since I am using a throttle position sensor.
Old 05-01-2014, 10:28 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #273 (permalink)
gsmith660's Avatar
I am working the excelon outages
Old 05-07-2014, 07:05 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #274 (permalink)
Ken911's Avatar
Well I got the manifolds back from powdercoating today along with my upper valve covers. I'm happy with how they turned out. Plan on spending the weekend working on the intake plenums have the first one started but it has a long way to go yet.
Old 05-08-2014, 01:27 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #275 (permalink)
Ken911's Avatar
Oh ok I think you make it four of us nukes on here.
Old 05-08-2014, 01:32 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #276 (permalink)
beancounter
jwasbury's Avatar
Surely you can't be serious
Don't you need a MAP sensor somewhere so the ECU can adjust timing and fueling for boost? I thought throttle position only load sensing was a no no for forced induction applications (though I think it is done sometimes)
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 05-08-2014, 01:44 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #277 (permalink)
Ken911's Avatar
yeah i think your correct i think i was getting that confused with using a mass flow sensor, which i think doesnt use throttle position or boost. I have a map sensor in the box along with a tps and a boost contoller, fuel sensor, temp sensor, and a ms-3 knock controller card.
Old 05-08-2014, 01:47 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #278 (permalink)
Ken911's Avatar
well I put on the manifolds and ITB's to check clearances. I'll need to put some shorter studs in the heads the clearance between the some of the studs and the vacuum ports are really tight. Some of them don't sit flush. The air horns will be welded to the bottom of the plenums. I'll buy a couple extras to use for balancing the throttle bodies when i get it running.
Old 05-09-2014, 11:32 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #279 (permalink)
You could cut the studs you have shorter with a cut of wheel on a die grinder and then smooth off the sharp edge.
Also, if you still have your CIS stuff sitting around the air flow meter housing has two short 8mm studs in it over on the right side down below the fuel head that hold the steel bracket on for the single 8mm mounting nut on the bottom of the stock air cleaner housing.
They are about 1.1" long and may be too short.
Old 05-09-2014, 11:48 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #280 (permalink)
