Minimalists approach, without the idiot lights, switches, etc. on the gauge panel. The wring is completely new too, a Ron Francis wire works eight circuit kit. New electrical everything
Rod
"This Year ferrari's Ass is Mine"
Old 11-20-2013, 06:51 PM
Bully's Avatar
Probably a stoopid question, but I was under the impression that the top of the dash was not accessible with the windshield in place. Mine is curling from the sun and I would love to recover it, what's the secret?
Old 11-21-2013, 11:54 AM
sudo apt-get purge 930
equality72521's Avatar
That 3M Super 77 may not hold up once the sun heats it up. I spoke to an upholstery shop when I was buying materials to redo mine and they told me this. I ignored them and used 3M Super 90. Within a month every valley was separated.
--clutch-monkey
Old 11-23-2013, 04:28 AM
yup I was told the same and I went with the Lepage contact cement instead of the 3M super 77.
Old 11-23-2013, 09:59 AM
930T Owner
Hams930T's Avatar
Not true unless you have a 964/993 dash. Based on your avatar picture you have an older car that does not have the metal tabs in the dash. If that is the case, then it is possible to remove/install the dash with the windshield in place.
I read the same thing from this board. When I went to restore my interior, I found out very quickly when I removed my dash that it wasn't necessary to remove my windshield at all. I would have saved a lot of time and money.
Chris.
Hams930T
1986 930
2015 991 GT3
2016 Cayman GT4
2012 911 Cup
Old 11-23-2013, 10:12 AM
No not a stupid question. I was able to remove the dash pad without removing the windshield and then I did the recovering.
Rod
Old 11-23-2013, 10:29 AM
Old 07-05-2014, 06:42 PM
Chain fence eating turbo
Clean! Love it. I'd love to do similar. Probably cheap too?
Old 07-05-2014, 07:40 PM
Thank you, fairly cost effective.
Old 07-05-2014, 07:44 PM
RS carpets? Or custom??
Old 07-05-2014, 07:50 PM
jbrown's Avatar
It will separate for sure. The 77 glue is good for carpet it does not hold up well with vinyl. I use 3m contact cement for all my vinyl. I don't remember the model of the glue but it is green and works with heat. once it is on it will never come off. I recover dashes and panels all the time and if you use the 77 you will be sorry....
Old 07-06-2014, 05:23 PM
jbrown's Avatar
dash look nice by the way
Old 07-06-2014, 05:24 PM
Thank you. Yup we used the contact cement too, Its never coming off
Old 07-06-2014, 05:57 PM
lin7310948's Avatar
i am a bit of a minimalist as well...but i used livorsi gauges!
71 911 all alum 434 sbc 585 chp 1959 austin healey bn-6 sbc zz4 motor 200r4 aod transmission......1959 Austin healey bn6 250 chev in line six cylinder, tremec 5 speed
Old 07-07-2014, 06:35 AM
torresmd's Avatar
I think it turned out great. I really like it. Great Job!!
1986 930 Slant nose Black/black RUF
2004 996TT Gaurds red/Black EVO GT 660
2001 Ferrari 360 Spyder Rosso/Tan
1969 Carrera Widebody TurboKraft Custom (Mexico Blue)
2001 E39 M5 Imola/Black-red interior
Old 07-07-2014, 06:56 AM
Nice work
Beautiful job! I'm gonna check those gauges out, thank you. Auto meter tach was a test, its to small in dia. looks lost. I'm not sure about the silver face either, I might go traditional black with white numbers?
Any detail shots of your gauge cluster you care to share?
Rod
Old 07-07-2014, 02:51 PM
Thank you for the nice comments gents!
Rod
Old 07-07-2014, 02:53 PM
lin7310948's Avatar
i used livorsi since several of the functions were tied into the ecu. and, i liked the gps speedometer. you might also consider speedhut gauges. lots of custom features available as well as color combos.
Old 07-07-2014, 04:39 PM
That looks great... bet it wasn't cheap.
Rob Montgomery
'88 Blk/Blk 930 ('Lucy') - Not Stock & Not Running
Old 07-07-2014, 06:40 PM
Thank you.
Old 07-08-2014, 05:59 PM
