H1 headlights in 930
Are 70's H1 headlights "plug and play" in a 79 930???
Are the housings bolt in?
Is the electrical plug the same?
Thanks John
Old 09-20-2013, 09:35 PM
Hi John,
I installed mine over 20 years ago but IIRC it waqs all plug and play. The housing slips on over the fender using the trim ring and the single screw at the bottom. Very snug fit especailly when trying to remove.
Rahl
Old 09-20-2013, 11:55 PM
Plug and play. I would suggest three things having done this a few times:
- Rub a tiny bit of wax or dry lubricant on the inner bezel lip or the fender's tabs that grab the bezel...will help it go on...sort of.
- No need to use a super high output bulb. The stock 55W is what the system can handle or you need to upgrade the fuse and wiring to the headlight switch (again, don't remember the specifics of the wiring upgrade but well documented here).
- Make a mask out of clear vinyl to protect the lens as these are pricey now.
Old 09-21-2013, 07:58 AM
Plug and play. I use 100W...
Old 09-21-2013, 01:15 PM
thank you everyone
Old 09-21-2013, 10:15 PM
Tilikum Turbo's Avatar
Just curious...what does a set of those H1's run?
1983 911 3.3L Turbo(YES, I know the turbo badge is on the right...had to be different!)
1996 Toyota Corolla(der 'clapper')
Old 09-22-2013, 08:16 AM
$1,300 for really well restored set, ie re-zinc and re-chromed housing, reflectors, etc
Old 09-23-2013, 09:56 PM
3 restos WIP = psycho
kenikh's Avatar
So the H1s are not original? Time to swap them onto my 69S, I guess.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 07-01-2014, 10:26 PM
