Throttle sticking on 77 930
Did a search but couldn't come up with anything. The throttle constantly sticks on my 930 when driving - doesn't do it when just revving up the motor. When going down the interstate, it is like it has cruise control. Will hold what ever speed you are traveling at until you touch the clutch pedal, at which time revs will drop to idle.
Mechanic says this is common and that the linkage bends from me pressing too hard on the accelerator. He has straightened it out but apparently I keep bending it - he even showed me how to straighten it by prying with a screw driver. However, there must be a better fix. Does anyone know the solution?
Thank you,
Ted
Old 10-01-2013, 03:08 PM
stevie 77 930's Avatar
Check your throttle lever in between the front seats. Make sure its not pulled up. Even if it is not, it could still be the culprit if the plastic has broken off and has caught on the linkage.
1983 911SC
1977 930 Turbo (again)
2018 GTS
2023 Audi A4
'74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone)
Old 10-01-2013, 03:28 PM
Thanks Steve. Seems to be right next to the accelerator pedal as I can pry on the rod there and it will stop for a while. Mechanic says I need to not push so hard on the accelerator. :-)
Old 10-01-2013, 06:51 PM
mcguff73
I had this problem and fixed it with a throttle stop located under the gas pedal. I think I bought it here on Pelican
Old 10-02-2013, 05:42 AM
...Mechanic says this is common and that the linkage bends from me pressing too hard on the accelerator.
WOT is WOT regardless of how much pressure you put on the pedal, there should not be much pressure to get you there, it is just a flapper rotating 90*. I would consult another mechanic... BTW, not commom - M2c
Old 10-02-2013, 06:38 AM
