-   -   G50/50 convert question (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/773132-g50-50-convert-question.html)
vinyl_tien 09-24-2013 07:56 AM
HI
I want to convert my 86 930 to G50/50 trans, plan to cut the torsion bar also reinforce it.
My question is can I use original transmission mount or do I have to buy a mod one like turbokraft made?
The second question, With this setup, Do I have to move my engine mount backward? to make more space for G50?
Need you guys input, thanks!
http://forums.pelicanparts.com/uploa...1380038126.jpg
Rodsrsr 09-24-2013 09:20 AM
I dont think cutting the torsion tube is the preferred method anymore. Short Bell housing G50 or having yours shortened is the way to go.
totle 09-24-2013 12:34 PM
As rodsrsr state, not the best option to cut the torsion bar.
If cutting the torsion tube, it will have to be modified and stiffened. Also the shock towers will have to be stiffened to be able to take the load from the coilovers.
I have just recently upgraded my 79 930 with a g50/01 transmission.
I shortened my g50. I took time to research since I did most of the job myself.
I has a machine shop to shorten the bellhousing and axel for me.
There is quite a list of other parts that needs to be upgraded but I guess you are aware of all the parts needed.
I used the original transmission mount, but had to weld on an extra flange since I had to move it backward.
vinyl_tien 09-24-2013 02:38 PM
Thanks Rodsrsr and totle
I live in Taiwan, it is hard to find machine shop to do shortened G50.
Right now my car is in body should, I already have reinforce parts for shock tower and coil over kit for rear suspension.
I have 930 shorten bell house transmission(from a 76). It will go into my 73 911 next year. I also have a 87 930 transmission which pull out from my car.
Should I take it as a sample for shortened G50? or just compare the different?
TurboKraft 09-25-2013 09:29 AM
Is there a reason you want the 1989 G50/50 Turbo instead of a 1987-89 Carrera G50? Everything else equal, yes, the G50/50 has a larger ring gear and thus a higher torque capacity -- but it is also a longer transmission (outside dimensions) with tall gear ratios for top speed.
Frankly, the Carrera G50 ratios are really more fun for street driving, and if you need more top speed then you install a Turbo 5th gear. And I've put 700hp/600tq through a shortened Carrera G50 in a car using 12" wide near-slick tires, no problems.
Shortening the transmission housing makes it far easier to install, almost a bolt-in to a chassis that had a 1978-88 "long" 4-speed transmission.
vinyl_tien 09-25-2013 04:00 PM
Hi Turbokraft
Thanks for the tips, really appreciate, the reason I want to cut TB is my car is in bodyshop, I had do some research and tell my bodyshop techman, they tell me they can do it cheap in Taiwan(extra 1000usd).
I don't know cut the TB and reinforce will strong enough like factory.
If I want to shorten my trans, I can ask my tech to separate bell house and main shaft and ship it to you, is that possible to done it?
TurboKraft 09-25-2013 04:47 PM
Sure, you can ship us a mainshaft and bell housing and we can shorten them for you, ship them back ready to install.
Cutting out the center of the torsion bar housing -- this is okay, provided the body shop takes care:
(a) to not let the torsion bar housing move relative to the chassis, and
(b) reinforce it to the chassis a lot.
After all, it is the inner trailing arm mount, too. It has to be strong and in the correct location.
Not long ago we had a car in where the center had been cut out, and they had allowed the cut ends to shift relative to the chassis prior to re-welding. Proper alignment was impossible, and it had to be re-done -- triple the work vs. doing it right the first time.
Cut out the tunnel enough and you can fit a 993's 6-speed if you want.
Tippy 09-25-2013 07:38 PM
Chris, the 700hp car had a billet diff cover I assume?
Anastasios 09-25-2013 10:21 PM
I will not cut the torsion tube at all.
You can have your bellhousing and mainshaft shortened as already mentioned.
Also how many HP do you expect from your engine ?
G50/50 is double or even more pricey than an non turbo G50...
Many people use with good results an non turbo G50 with a turbo engine...
Tasos
<!-- / message -->
TurboKraft 09-26-2013 08:12 AM
No, that particular one had a 993 side cover fitted to it.
At the time, the billet side covers were solid slabs of aluminum, not very high quality. They're better now, and I'd incorporate one in a transmission used with a very high torque engine.
Hams930T 09-26-2013 08:17 AM
Do you guys offer a G50 conversion package? I would really like to discuss with you if you guys do....
Thanks,
Chris.
TurboKraft 09-26-2013 09:40 AM
Thanks,
Chris.
Yes, contact us by phone, email, or PM and we'll go over the options and details for your build.
Tippy 09-26-2013 05:28 PM
<div class="pre-quote">
Quote de <strong>Tippy</strong>
</div>
<div class="post-quote">
<div style="font-style:italic">Chris, the 700hp car had a billet diff cover I assume?</div>
</div>No, that particular one had a 993 side cover fitted to it.<br>
Thank you so much! Going to order one soon and put my worries to rest.
Rodsrsr 09-27-2013 07:45 AM
Its my next project as well. :cool:
mamut 09-27-2013 09:08 AM
You should get in contact with Albert, at Blank, he is in Taiwan, (Going Superfast) he can provide you with the services you need done on your tranny.
Tippy 09-27-2013 09:31 AM
</div>
<div style="font-style:italic">Thank you so much! Going to order one soon and put my worries to rest.</div>
</div><br>
Its my next project as well. <img src="http://forums.pelicanparts.com/ultimate/cool.gif" border="0" alt="" title="Cool" class="inlineimg">
You know, now I can't find one....
mamut 09-27-2013 09:37 AM
What do you mean by the late covers been better, as in looks? 'cause I will think that a slab of aluminum will be stronger than a ribbed one, just my opinion thou.,
Stefan.
TurboKraft 09-27-2013 10:06 AM
Stefan.
Actually, a solid slab is not stronger in this instance, nor is it weaker. Most of the metal is seeing no real load, so it's just a lot heavier.
If correctly lightened, there is no loss in stiffness and support for the bearing. This is easily confirmed with load simulation applications integrated into 3D modelling software like SolidWorks.
Example: WEVO's super nice billet side covers for the 915 transaxles. A fraction of the weight of a solid slab, no loss in rigidity.
http://forums.pelicanparts.com/uploa...1380305050.jpg
TurboKraft 09-27-2013 10:33 AM
Billet side cover, or a G50 transmission?
Last week and earlier this week I came across a few G50s. Email or PM me.
Tippy 09-27-2013 02:46 PM
No, the OEM 993 side cover. I'll machine the speedo boss. :)
