930 radio antenna fuse
1979 930
Was cleaning/servicing the original antenna. Got it working great. Then when I was hooking up the last connection, I shorted. Can't figure out where the fuse is for the radio antenna/radio. There is what looks to be a small glass or ceramic fuse in an inline tube fuse holder but it looks ok. |
Preferred pronoun:Maestro
Factory radio or aftermarket? You might want to provide a make & model or pic.
When in doubt, use overwhelming force. |
Can't believe no one knows this??
It's OEM Bramberg radio with OEM antenna. |
Found it.
Fuse is under radio. In line fuse. In plastic holder. Glass fuse 5mm by 20mm 2A/250V (slow blow). It powers radio AND antenna. |
