Kozmo930's Avatar
Porsche Crest new porsche parts
Hello fellow pelicans ...
Thanks to our good friend "Profighter" , Roland to others he was kind enough to send me a CAD program to make some air block off plates for my 930 front rotors. I set up a deal with a machine shop here locally that does water jet cutting and had some made to see how they fit. Well as you can see in the following pics I would say pretty good fit , only need 2mm longer bolts to take up what you loose from the plate thickness.
I also had them cut some injector blocks I purchased from our host to 36mm for my new EBS cams I had upgraded for the turbo motor I'm building.
So if anyone is interested let me know after the holidays , everyone is going on vacation and wont be back till the 2nd week in January.
Thanks Kozmo
Old 12-21-2013, 08:55 AM
Kartoffelkopf
Spenny_b's Avatar
Nice job!
Excuse my ignorance, and I did see these parts on Rolands thread as well, but what do the rotor plates actually do (apart from blocking air....from where and why?)...I've never seen them before.
Spencer
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html
On Instagram (along with other stuff) as @spenny_.b #spennybengineproject
Old 12-21-2013, 01:28 PM
Originally Posted by Spenny_b View Post
Nice job!
Spencer
Ditto question - They look like something I'd want, but what do they do??
thanks
Old 12-21-2013, 03:50 PM
rsrfan's Avatar
Nice job!
Spencer
When ducting air to the brakes the block off plates force the air outward through the rotors instead of allowing it to escape through the openings around the hub...
I'm sure someone will come along shortly and clarify in more technical or eloquent terms, but this is the basic premise...
Old 12-21-2013, 04:40 PM
Kozmo930's Avatar
Everyone seems to have the idea... yes when running cooling duct hose to the center of rotor , air runs out the rotor vanes. But with these plates the air is forced to all go out the vanes and nothing escapes to the hub area.
Kozmo
Old 12-21-2013, 05:36 PM
Kartoffelkopf
Spenny_b's Avatar
Ah, I see, thanks for the explanation guys.
Old 12-22-2013, 01:34 PM
