I'd like to know how they got it to work. Maybe they programmed it as an 8 cylinder in TunerStidio or MegaTune?
Email Protomotive: sales@protomotive.com
Todd is a good guy, they mainly do 996-997 mods but I would doubt he can't sell you a chip and RRFPR. For low boost it's perfect and very easy, you retain all the motronic cold/hot start etc which I think is pretty good. I went this route and it is very simple. The other plug and play option would be these guys. Canems Engine Management Solutions |
I already offered my Proto kit to him, the cheapest, easiest route.
Canems is crazy overpriced. |
VEMS can read easily 944, 951 and 3.2 trigger wheels, also Audi 20V Turbo's 3 triggers (135+1tooth flywheel and additional HALL cam sync) already from 2006. |
Accel also makes a billet drop-in "Dual Sync" distributor #77911. It is fitted with hall-effect sensors for flywheel speed and camshaft synch.
Add a no-frills CDI & coil, and that's more than enough ignition for 550whp: http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/640609-taking-efi-plunge.html |
| All times are GMT -8. The time now is 05:45 PM. |
