Confused about pressure plate numbers
Hi guys
Just removed my engine in my 89 turbo
The clutch has been replaced with a spring type in the past
Have a question on the pressure plate
The one on the car is part number
950 116 023 50
when I do a search it shows for a rubber disc.
Can we use this preasure plate with spring disc?
The spare one I have and was going to install says
303 205 3099 and it also says 930 116 021 03
What is the difference with the stock ones I have and the replacement ones ?
Old 12-15-2013, 03:43 PM
TurboKraft's Avatar
950-116-023-50 = stock iron pressure plate for a 1989 Turbo with a G50/50 5-speed transmission.
You can use a spring hub organic disc with it, #930-116-014-02, about $400.
930-116-021-03 = stock iron pressure plate for a 1978-88 930 with a 4-speed transmission. It will not work with your flywheel and 5-speed.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 12-16-2013, 09:17 AM
Thank you i guess will not need thr 930 116 021 03 and clutch is going on clasified
Old 12-16-2013, 01:46 PM
