Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
911 sc series twin-charging
Hey guys! After lurking for some time now, I decided to join this community to ask the question that has been eating away at me for a couple of months now. I hope that you can help.
The 911 sc is my dream car. It provides speed and nostalgia, but is still fairly decent price-wise. After wanting this car for a while, I started thinking about all of the upgrades that I would love to do to this car if I had all the money that I could ever need. I came across the idea of series twin-chargers. That is, running the compressed air of a supercharger into a turbocharger. This eliminates spool time, and yields great increases in pressure.
All practicality aside, my questions are:
Is it possible to twin charge a 911 sc (any year, the year doesn't matter too much to me as long as it works) without the engine exploding. The major challenges would be the immense pressure in the engine, and the high temps caused by the pressure increase.
If so, what upgrades would be needed to do this? (E.g. Intercooler, upgraded pistons, etc.)
What kind of psi gain could I expect?
What kind of horsepower gain could I expect?
Now the practical questions:
What would the immediate cost be?
Possible long term costs?
And finally, how long would the engine really last under these circumstances?
The supercharger that I was thinking about using: Whipple W140-AX Supercharger (2.3 liter) Direct-drive WSC-140AXB-DD (BLACK)
The turbocharger that I was thinking about using: https://www.moranmotorsports.com/product/garrett-gt3776-55mm-journal-bearing-turbocharger
Sorry about the wall of text, I just had to know.
Old 12-18-2013, 04:36 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
clutch-monkey's Avatar
i'll leave specs on what kind of engine rebuild you'll need to posters who have done it, but i'd personally spend a good while sorting out space constraints/ducting and pipework perhaps - sounds like it could get crowded in a hurry?
Old 12-18-2013, 05:19 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Oops, I guess that I didn't really realize that space would be such a large constraint, but it would definitely fill up fast in there. Assuming that I could overcome that, is it still possible?
Old 12-18-2013, 05:34 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
I'm starting to think that the GT4294 would be a better turbo. It has 74% efficiency instead of 68% and it still uses the journal bearing, which is the most durable kind. If I'm not mistaken, higher efficiency means the air being put into the engine is cooler, meaning that I could use a slightly smaller intercooler. Any thoughts on this?
Old 12-18-2013, 07:18 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
Sounds like a $40k engine to me.
Old 12-18-2013, 07:52 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
Chain fence eating turbo
That's not worth the effort IMO. And a GT4294 is a huge turbo!
Read up on Garrett's websites regarding efficiency in their beginner, intermediate, and expert turbo tutorials. The one you spoke would not be efficient on a 3.0 since it's so big.
Old 12-18-2013, 08:48 PM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Okay, so it's probably pretty obvious that I don't know a ton about turbos. Can you guys give me any recommendations? Ideally I would have one small and highly efficient supercharger running into one small and highly efficient turbocharger, total psi gain being somewhere between 10 and 20ish. The PSI's are multiplied when running in sequence (but must first be converted into pressure ratios if I remember correctly), as are the efficiencies, e.g. 50% x 50% = 25%. For more info check out this wiki article.
Twincharger - Wikipedia, the free encyclopedia
Thanks again guys.
Old 12-18-2013, 09:03 PM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
i will say pretty much anything is possible if you throw enough money at it..
not to be a nay-sayer but it's going to be a pretty big and complex project!
Old 12-18-2013, 09:43 PM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
sjf911's Avatar
The SC has quite a few inherent limitations stock to increasing horsepower and torque with forced induction beginning with a relatively high compression ratio and air cooled heads which dramatically affect detonation sensitivity. You also don't have fine control over air fuel ratios and ignition timing with the stock induction/ignition systems. Then there is the inherent weakness of the stock 915 transmission in high torque applications which has been graphically demonstrated more than a few times on this board.
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 12-19-2013, 06:07 AM
  Pelican Parts Technical Article Directory    Reply With Quote #9 (permalink)
The path of the warrior.
Rodsrsr's Avatar
Kinda like this....I guess you could but why?
To GI or not to GI.....
Fear the Heel Hook
1976 Turbo Coupe 3.2
2009 Carerra S (997.2)
Old 12-19-2013, 04:02 PM
  Pelican Parts Technical Article Directory    Reply With Quote #10 (permalink)
Brando
quattrorunner's Avatar
Kiss
Old 12-19-2013, 04:27 PM
  Pelican Parts Technical Article Directory    Reply With Quote #11 (permalink)
TurboKraft's Avatar
+1 on k.i.s.s.
Have you driven a 911 with a properly built and tuned Turbo engine?
How about one with EFI?
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 12-19-2013, 06:15 PM
  Pelican Parts Technical Article Directory    Reply With Quote #12 (permalink)
xbmwguy's Avatar
rod, that car aint for a short guy but i would love to hear it driven in anger!!!!
Old 12-19-2013, 07:07 PM
  Pelican Parts Technical Article Directory    Reply With Quote #13 (permalink)
Large Member
krasuskyp's Avatar
no need for wheeliebars on the Hotwheelsmobile
visibility = overrated!
would only need to see as far as the nearest gas station at least
Paul... CT | '87 930 | '07 //S6 v10 JNR | '98 ///M3 vert |
past:
| '01 ///M5 | '96 993 C2 cab | '05 S600 Sport - biturbo V12@Just Not Right 495rwhp / 612rwtq |
| '58 TR3A | '01 //S8 | '95 //S6 6gang | '88 ///M5 | '87 190E 2.3-16 |
Old 12-20-2013, 05:39 AM
  Pelican Parts Technical Article Directory    Reply With Quote #14 (permalink)
copbait73's Avatar
And by the looks of the drive belts the blower housings are empty.
Maybe he adapted forward collision alert.
Old 12-20-2013, 09:43 AM
  Pelican Parts Technical Article Directory    Reply With Quote #15 (permalink)
Rodsrsr's Avatar
No its fully functional. Both engines and all 4 blowers work. It was featured here.
1927 Ford Model T Dual Engined Quad Supercharged T Bucket - R&T DRIVE Videos - Road & Track
Fear the Heel Hook
Old 12-24-2013, 09:45 AM
  Pelican Parts Technical Article Directory    Reply With Quote #16 (permalink)
Tags
911 sc , targa , twincharger
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
