T77911S's Avatar
got an air leak at #3 intake.
found it last night with the help of a new friend that has a shop down the road.
i have stopped and talked to him off and over the past few years. he is big into BMW and mercedes. he has an 88 M6.
we found it with spray. then we tried to smoke it to be sure but we could not see anything. then we sprayed water at it and it about died.
he suggested putting a straight edge onthe intake and the heads to make sure they are true. what do you think? does it happen?
i am thinking the waste gate air leak was the original problem and i created this one when i pulled the intake. i did have problems with the intake bolts coming lose but i put blue loctite on them, which i regreated as soon as i did it because now i cant tell if bolt is lose again. i hope the studs are not pulling.
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 01-17-2014, 04:41 AM
Turbo Hooligan
Sounds like just a cracked injector block, I had it happen years ago. pulled the manifold and CIS off the top of the engine, replaced all 6 with aluminum blocks(I believe Chris at TK is the current goto source)
and never had another problem.
the OEM blocks just get brittle over the years and crack.
www.d-zug.com
blog.d-zug.com
All these guys do is drive too fast, work on cars, chase ******* and drink.. really no fun at all...
Old 01-17-2014, 07:29 AM
How much torque had you put on the intake bolts? The shop manual says 22ft lbs. Some of mine were also quite loose, and the car was running fine. During winter maintenance I snug them up to 13 lbs, as cranking down any tighter on the plastic injector blocks feels too close to the threshold.
Old 01-17-2014, 08:18 AM
injector blocks
I have some 40mm aluminun injector blocks in the FS section if interested.http://forums.pelicanparts.com/porsche-911-used-http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/791637-cis-injector-blocks-930-a.html#post7854975parts-sale-wanted/791637-cis-injector-blocks-930-a.html#post7854975 Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Old 01-17-2014, 08:20 AM
T77911S's Avatar
link did not work
i just put new blocks on.
18ft of torque.
what do you think about there being a problem with the heads or intake not being true?
Old 01-17-2014, 10:00 AM
83 911 Production Cab #10
JJ 911SC's Avatar
Let me fix that for you Phil...
cis injector blocks for 930
Who Will Live... Will See
Old 01-17-2014, 10:19 AM
