'77 930 X '86 930 tranny
What is the difference between a '86 and a '77 930 tranny? will a '86 tranny fit in a '77 930?
Thanks in advance,
http://917burger.blogspot.com
Old 01-20-2014, 06:19 PM
Robbbyg's Avatar
Im sure it can be done..
if you Do do it ill be interested in your 77 tranny if you want to sell it
Wheels
Last row 1977 3.0 930 260hp built, still reassembling
Row 1998 996 MK1 3.4 296hp new daily driver
Old 01-20-2014, 06:27 PM
Unfortunately, I bought the car with no tranny...
Sorry,
Old 01-20-2014, 06:29 PM
bahnzai's Avatar
The '86 tranny is longer. It can be modified to fit, it requires the main shaft and bell housing to be machined. Patrick Motorsports does it here in the USA. You may be able to find someone with that expertise in Brazil too..
Danny
'83 930 track beast
'73 914-6 3.6
'70 914-6 (looong term restoration)
'74 TR-6
Old 01-20-2014, 07:06 PM
7.0:1 > 11.3:1
The short answer is no, it will not fit. The 75-77 trans is shorter than the 78-88 as bahnzai describes above
Old 01-20-2014, 07:47 PM
It will not fit unless you do the following. All you need is a 76 or 77 mainshaft and bellhousing transplant, or send your 88 930 bellhousing and mainshaft to Patric motorsports to be remachined to 76-77 specs. I had a 88 shortened about 5 years ago to put the it in a 911SC which is the same chassis length as a 76-77 930. Since then I have gotten a spare original 77 930 bellhousing and mainshaft and a limited slip 936 diff with some extra transmission parts that came with a trans that went the other way to be a long bellhousing race trans for a 1985 930.
Anthony @ Voitureltd Bayside WI.
Old 01-20-2014, 08:12 PM
