Robbbyg's Avatar
Can you Get more life out of a clutch?
My clutch has been slipping when under high boost, so i adjusted it yesterday to the 1mm gap,it didnt help in fact possibly made it worse..
If i were to adjust it wider say 2mm would that give more clutch grip? or is there anything else i could do to fix the problem without taking it out and replacing?
Wheels
Last row 1977 3.0 930 260hp built, still reassembling
Row 1998 996 MK1 3.4 296hp new daily driver
Old 01-23-2014, 06:35 PM
Banned
Unfortunately, the answer to your question is no. If the clutch is slipping, and the cable and arm gap are adjusted properly, then either the friction material is worn off, there is oil on it, or the pressure plate tension springs are worn/damaged. If you have any gap at all at the arm, then the release bearing is not putting tension on the pressure plate springs, so an even larger gap will have no further effect with regard to clutch slippage.
Old 01-23-2014, 06:48 PM
mark houghton's Avatar
As Ronnie said.....not happenin'. Sorry. Now you gotta wade through all the opinions on what clutch to replace it with. My opinion is already out there, so I won't bother.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 01-23-2014, 08:14 PM
Large Member
krasuskyp's Avatar
Bummer Robbby, sorry to hear - good luck.
I'll confess... there's days where I think you made up your user name / location / persona / issues just to eff with all us idjuts here on the forum. Your posts are - er uh ummmm - unique?
make all my posts & problems seem normal / trivial
8-) of course... you seem a real good dude and mean well enough.
Here's to hopin the tables turn for the positive wayway down there for ya! I know I'm rooting for a roof to fall upon your '76! Keep fighting the good fight...
Paul... CT | '87 930 | '07 //S6 v10 JNR | '98 ///M3 vert |
past:
| '01 ///M5 | '96 993 C2 cab | '05 S600 Sport - biturbo V12@Just Not Right 495rwhp / 612rwtq |
| '58 TR3A | '01 //S8 | '95 //S6 6gang | '88 ///M5 | '87 190E 2.3-16 |
Old 01-23-2014, 08:33 PM
Robbbyg's Avatar
Hey its all Good i do suffer a minor disorder (930adhd) i wont go into here but it does lead to confusion from others im used to it
gets me thinking though,
Answer Number 2 says Oil or slippage..
Ok ill get in there and spray the heck out of it with a degreaser..
If still slips then it is worn
now the clutch in my car isnt normal for the period as the car has a late 915 gearbox, lightened flywheel and a lsd. (some of those are not standard for the year)
Clutch type who knows i havent found any reciepts on that..
So say if its a Period clutch, these were made out of rubber i think..
And if thats the case i may have found another good use for my Beltgrip spray
If i get more miles its worth trying
Wheels
Old 01-23-2014, 10:43 PM
Banned
Spraying degreaser on the clutch assembly won't do any good, as any oil that "might" be on it will have impregnated the friction material, which you can not see without removing the pressure plate, and any degreaser that you spray on it through the bell housing inspection hole will do absolutely nothing. Also, if there is enough oil there to make the clutch slip, you will see it running out of the bell housing and so forth.
The clutches were never made out of rubber, but many years, including in the 1980s, had clutch discs with a rubber center section, or carrier, which is know to disintegrate over time. They were a horrible idea meant to lesson noise and vibration and most people have replaced them with a conventional spring centered clutch by now. Your beltgrip spray isn't going to help you out here.
And I hate to be a killjoy, but if you continue to drive the car with clutch slippage, then the lightened flywheel you mentioned will be a "goner" in short order.
Old 01-23-2014, 11:03 PM
Robbbyg's Avatar
Is the bell housing inspection hole accessible without any dissambly?
Wheels
Old 01-24-2014, 12:36 AM
Ronnie is 100% right on in his post.
At the least you need a new clutch disc and if you continue to drive it and let it slip it will ruin whats left of the clamping surface of both the flywheel and pressure plate by creating little blued steel raised hot spots.
Those swirled blued steel hot spots are harder than the rest of the steel surface and become raised above the rest of the surface and that makes the clutch disc wear faster and become grooved where they are on the flywheel and pressure plate.
Blanchard grinding can restore a Porsche flywheel if it hasn't become too worn and KEP pressure plates can be rebuilt but a stock sachs pressure plate gets replaced.
Old 01-24-2014, 07:33 AM
Banned
Yes - it is on the right side of the bellhousing. You can't really "see" much and will need to use a small mirror and flashlight.
Old 01-24-2014, 09:58 AM
Robbbyg's Avatar
Thanks guys,
ill go in there and see what i can see in there
Another question, how much should i pay for a reasonable clutch?, i just want a hard wearing one, nothing flash , ill be shopping on Ebay
But they all look the same to me, (not being racist)
Wheels
Old 01-24-2014, 04:43 PM
OG
///Criss's Avatar
Mine is doing the same thing....... Bummer. Already called Chris at TurboKraft...
2002 Suzuki Hayabusa SE... Mega Crotch Rocket!!!
1988 BMW M3.... WWWRRROOOMPP!!!!
1983 911SC (long term Project)
1987 930 GP White Woooosh!!!!!! Burble burble!! Hahaha
Old 01-24-2014, 08:06 PM
Robbbyg's Avatar
Time for me to get out the 101 projects book
Wheels
Old 01-24-2014, 09:11 PM
Robbbyg's Avatar
Why dont they make them out of Ceramic or carbon fibre or silicon Carbide ???
Would save a lot of trouble
Wheels
Old 01-24-2014, 09:13 PM
