need to ID this turbo transmission with cooler
I could not find anything on a Google search appears to be a lsd turbo transmission with side cooler
787/12/0136 GAMMA p/n 930 301 101 OR dated 12/77 mid section 930 301 102 OR 40/6
race box??
thanks
Old 01-24-2014, 04:08 PM
Robbbyg's Avatar
race box??
thanks
Hi i found this on gearboxes
Quoting from another source so i cant vouch for accuracy-
For the earlier cars, the numbering was much shorter, and not very descriptive. The cutover was at the end of 1987, for 1988 models. So the first G50's in 1987 used the "old" numbering scheme.
The main identification is on the bottom of the transmission, in the middle, on a raised surface, which is sometimes scraped from bottoming out on the pavement.
Example, 73H 06841
7 is the transmission type
3 is the transmission version
H is the model year, H=1987, I was skipped, J=1988, K=1989
06841 is the serial number, starting from 1. Swiss version started at 20001.
Types
73 = G50.00
74 = G50.01
77 = 930.36 turbo 4-speed
Before 1982, the numbering had 1 less digit, and the model year was a single digit. 1=1981.
778 = 930.34 1978 model
779 = 930.34 1979 model
770 = 930.34 1980 model
771 = 930.34 1981 model
77C = 930.34 1982 model
77D = 930.34 1983 model
Endquote
Wheels
Last row 1977 3.0 930 260hp built, still reassembling
Row 1998 996 MK1 3.4 296hp new daily driver
Old 01-24-2014, 08:21 PM
gearhead
Those are casting numbers.
Type number and serial number is on the bottom rib next to the drain plug.
Old 01-25-2014, 09:19 AM
