935TURBO's Avatar
What about that kind of fittement..?...any feedback...?...thanks
I saw that....what are your thoughts...?....thanks for feedback...
Serge, Gentleman Driver
https://www.facebook.com/photo.php?fbid=10207116408000968&set=gm.1723624077 855805&type=3&theater
Old 01-25-2014, 05:43 AM
beancounter
jwasbury's Avatar
I think this set up is common when people do a turbo conversion on an NA 911 engine. It's easier and cheaper than fitting a separate scavenge pump for the turbo.
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 01-25-2014, 07:25 AM
935TURBO's Avatar
Thanks for your answer...
And are there any convinients to make such a fitment on a 930/66 engine...?
Old 01-25-2014, 08:13 AM
Crotchety Old Bastard
RarlyL8's Avatar
Do you not have a turbo oil pump on your 930/66?
A catch tank is a good idea as a volume buffer. The tank we manufacture has fittings on both ends. The right side can be routed to the engine sump if desired for more drain capacity.
Old 01-25-2014, 08:26 AM
Looks like it's been there a while, the case is real clean, and that's the first time I've seen a charge pipe used as a tailpipe.
Old 01-25-2014, 09:13 AM
935TURBO's Avatar
Thanks Brian an JF...
My goal would be to don't use an additional tank and pump...only gravity....
I explain:
when I use the K29, the pump overflows and the turbo repulses the oil by the exhaust and even worse when I start where the oil stagnated in the body of the turbo since the last run....
May be, without the pump, I wouldn't have this problem....?
Old 01-25-2014, 10:32 AM
RarlyL8's Avatar
I'd still us a tank so you can vent the overflow instead of backing up through the turbo seals.
The vent at the top of our tank has several different fittings to route overflow, a stock log tank will vent to the air filter housing. There is a problem somewhere if the oil input is not matching the pump output, best to fix or balance that.
Old 01-25-2014, 12:54 PM
