Robbbyg's Avatar
Life of a clutch
How long should a clutch last for with just daily driving zero burnouts no track days?
Brand? i have no idea the company who put the clutch in described the clutch but not the brand or number
It was installed new with new flywheel 12 months and 14000 km ago by the previous owner who had it replaced along with other parts in preparation for the sale
could any of these cause clutch to slip/fail??
Installing short throw gearstick
washing around gearbox and motor with high pressure hose, is it possible that oil has been forced in there?
****ty driving by me when my car had zero torque at the low end and often i had to ride the clutch to move the car off the lights?
also previously a 915 gearbox was added so i dont know what is in there..
Ive contacted the workshop (a supposedly expert company and they couldn't tell me what type they put in!!) even after i gave them the reciapt number, which if they still fail to answer ill be naming and shaming on their CR#ppy professionalism
Wheels
Last row 1977 3.0 930 260hp built, still reassembling
Row 1998 996 MK1 3.4 296hp new daily driver
Old 01-28-2014, 09:13 PM
Robbbyg's Avatar
Geez i dont know Robbby, maybe someone here might know??
Wheels
Old 01-29-2014, 02:31 AM
Functionista
manbridge 74's Avatar
Normal driving should give many thousands of miles/KMs.
I think the answer lies in the slipping the clutch part of your post.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 01-29-2014, 03:39 AM
Robbbyg's Avatar
Seems a short wear time, as it was used like that only a half dozen times till i fixed the timing..
Anyway im taking it all out tomorrow ill have a good look at it and get pics then
Wheels
Old 01-29-2014, 04:22 AM
H2odiesel's Avatar
Any signs of a rear main seal leak or a transmission input shaft seal leak? Either one is not conducive to long clutch life.
Old 01-29-2014, 04:34 AM
sjf911's Avatar
If you really have a 915 behind a 930 motor, a stock 915 clutch won't last long with any abuse.
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 01-29-2014, 04:37 AM
Robbbyg's Avatar
Yes i know, the clutch part number and model in the reciept is referred to as
Clutch Kit sport +20% Clamp whatever that means
Ive asked them exact specs but couldnt get them , i am lookng at a clutch kit locally and dont know if it will fit theres my dilemma
Wheels
Old 01-29-2014, 04:56 AM
sjf911's Avatar
That sounds like what I had, didn't last long. I now have a Centerforce.
Sapere aude
Old 01-29-2014, 05:26 AM
wjfk32's Avatar
This is what my 915-Disc looked like when doing a run-3rd gear on a cold night approx. 2 years ago.. Never got on 1 or 2nd gear.)
Went with a KEP-stage 2-915..Very happy with it.
Walt
Old 01-29-2014, 07:02 AM
wjfk32's Avatar
Old 01-29-2014, 07:05 AM
I averaged around 75,000 miles on a larger diameter pre 1974 BMW 2002 clutch with mostly normal driving.
With the higher torque of a 930 and the inevitable driver 'red mist'... it's probably gonna be less than that.
It depends on how much the driver slips the clutch on starts and how much highway or stop and go city driving.
Old 01-29-2014, 09:03 AM
Ken911's Avatar
ive had about 5 clutches in my car. last one is a KEP best of all of them.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
05 Cayenne S lapis blue
Old 01-29-2014, 10:10 AM
Tug68's Avatar
Just doing mine now installing a clutch from TurboKraft, Sachs performance.
Old 01-29-2014, 02:03 PM
Brando
quattrorunner's Avatar
I had a 915 sachs power clutch which is a regular aluminum clutch that is garanteed to hold specified torque. Mine held just the specd torque for about one year before slipping on boost. Some said it probably was slipping the whole time? The sport clutch holds better, I'm sure that's what you have. If your holding torque under boost, keep it. If your slipping now, it will only get worse with time. BTW the 915 won't last long either unless your really nice to it. I have experience there.
Turbo powa!
1977 911s. it's cool
Old 01-29-2014, 03:19 PM
6771911esses's Avatar
FWIW, when I had the 3LDZ in my car the clutch was fine...no slip on boost. After K27 upgrade...massive clutch slip when boost came on. I have a G50 LSD so I went with the 89 Turbo Clutch/ PP and it is holding up fine.
With the above said....there is an enormous amount of Torque (more than normally aspirated cars) on the clutch which can accelarate the wear.
Old 01-29-2014, 04:12 PM
Robbbyg's Avatar
Well i just got a excellent price From an excellent person, From an obviously Excellent shop -Chris at Turbocraft-
on a KEP Stage-1 aluminum pressure plate and a Sachs 915 disc, with slotted organic lining and spring hub which i think most of you guys use as minimum , But i will try to make happen that's for sure,
And there is no way ive done my clutch in after six months of driving, this is my third Porsche and this one i have driven more sedately then my others (im in the mountains here only one traffic light in 10 miles) which clocked up many more miles with no clutch problems on others, i think i mentioned the prev owner had just had it put in for the sale. id say it was an inferior clutch of some description, ill know for sure over the next couple of days when i clean out my garage and study how to do the engine drop etc. then proof will be in the bellhousing? pardon the bad pun
Thanks Turbocraft have added your online shop to my Bookmarks
Wheels
Old 01-29-2014, 11:49 PM
