Teardrop mirrors for a 1985 930 wiring help
I need help trying to wire up a set of tear drop mirrors on my 1985 930
They got fitted a while back and where left manual but now the fact the switch does not do anything is getting to me. I have found various threads but none seem to have the same wires as I have so I am looking for someone who has done this to tell me what goes to what and what else I may need tried I have doing it the trial and error way but now driving me mad
Wires on car are as follows
Drivers door:
Black/yellow
Grey/green
Brown
2 white
Green/black
Black
Passengers door
Blue
White
2 brown
Black
Grey/Green
If I need extra parts then where can they be brought?
If I'm sounding desperate that's because I am it's in my head now and starting to niggle so once again any help would be well received before I pull all my hair out
Old 02-03-2014, 10:40 AM
Anyone out there with the knowledge I seak?
Old 02-03-2014, 11:04 PM
Groovie Ghoulie's Avatar
pictures are usually far more helpful.
Old 02-04-2014, 08:08 AM
From research I have done looking through old threads being a pre 86 car I need conversion harness with solenoid
Bw Motorsport uses to do one apparently are they still about and does any one have a contact number as I can not find them on the net or anyone else do this item?
Old 02-04-2014, 08:15 AM
onboost's Avatar
Its not that difficult to figure out..
I've done it a couple of times years ago, to SC's that were being updated. Did not use the conversion harness with solenoid as supplied by BW. Everything worked fine.
I wish I could recall and impart the details to you. However, I do remember we figured it out with some time and several sets of jumper wires.
I will also be adding a set of these to my 930 in the next few months.. they're painted and waiting for me to find time to assemble.
RGruppe #180
Old 02-04-2014, 10:22 AM
When you do add yours send me some details and i will be eternally gratefull as I have been doing the trial and error method and I'm nearly bald because of it
Some things just get under your skin
Old 02-04-2014, 11:50 AM
totle's Avatar
I have a wire instruction somewhere. Let me look fort
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 02-04-2014, 01:59 PM
That would be grate look forward to it
Old 02-04-2014, 02:33 PM
