lin7310948's Avatar
need to check into the fm5s mentioned above...
71 911 all alum 434 sbc 585 chp 1959 austin healey bn-6 sbc zz4 motor 200r4 aod transmission......1959 Austin healey bn6 250 chev in line six cylinder, tremec 5 speed
Old 02-12-2014, 03:59 AM
MikeD930's Avatar
Keep the RH's and forget about those CCW's. As others said you can get wider rims for your RH's then mount larger tires.
MikeD
'87 930
Old 02-12-2014, 04:16 AM
Large Member
krasuskyp's Avatar
were you suggesting to the OP or asking me? If the latter, PM / email me for contact referral.
Keep in mind these are nooooo where nearly as uberawesomely dished as your set. The rears are decently dished, the fronts are moderately.
Never do tire of seeing or hearing about that build of yours there!
Paul... CT | '87 930 | '07 //S6 v10 JNR | '98 ///M3 vert |
past:
| '01 ///M5 | '96 993 C2 cab | '05 S600 Sport - biturbo V12@Just Not Right 495rwhp / 612rwtq |
| '58 TR3A | '01 //S8 | '95 //S6 6gang | '88 ///M5 | '87 190E 2.3-16 |
Old 02-12-2014, 05:48 AM
lin7310948's Avatar
no, i was suggesting to the original poster. i have always liked the fm5s and those are pictured on my car. i had fm10s but traded for a set of 5s. as to the poster, i would keep the rh wheels over the other wheels!
Old 02-12-2014, 06:05 AM
Fuchs or BBS RS.
Nothing else works on a 930
996 GT2
Old 02-12-2014, 06:11 AM
jbrown's Avatar
Here is a couple of pics. I changed the centers to black. I am going to get larger barrels in the future.
Old 02-15-2014, 07:37 AM
DA VINCI's Avatar
Very, very nice.
Old 02-15-2014, 11:47 AM
Tug68's Avatar
Looking good!
Old 02-15-2014, 08:19 PM
Techart daytonas 18" coloured centres
Tried gembellas first wanted ruf ended up with techart but pleased with result
Old 02-16-2014, 11:21 AM
Techart Daytonas
could not get photo on last reply
Old 02-16-2014, 11:40 AM
Large Member
krasuskyp's Avatar
the black centers look really awesome!
Very much changes the look, and compliments the black top & blacked out lens motif you got going.
Great way to freshin up the look - well done.
past:
Old 02-16-2014, 12:03 PM
gavinc69's Avatar
Yeah, nice
1980 SC Flatnose, Euro 3.0, LW Flywheel, 993 Cams, Port & Polish Heads, RS Cut Valves, MSD 6AL, Blaster Coil, Magnacor Leads, Boxster Brakes, WEVO Mounts, TRG Roll Bars, Rollcage, RSR rear fenders, OE Short Sift, K27 7200 Turbo Conversion, OBX Headers, Tial Wastegate, EFI MicroSquirt v3
Old 02-16-2014, 02:17 PM
I believe you said you do not have rear turbo 930 trailing arms. If that is the case you could actually run a 5.25" rear outer lip on your RH wheel centers. In the fronts I usually build with 2.75 if the car does not have turbo front hubs or spacers up front, or if you have turbo front end or spacer use a 2.25" outer lip. Here is a picture of a Speedline Daytona wheel that is in the configuration I described. It is 11" and is 5.25 and 5.50. Very deep rear outer lip looks good on certain cars. jdorociak@gmail.com jim
Old 02-16-2014, 06:40 PM
